Old 02-17-2003, 03:19 PM
Default Front clip wiring harness - needed
I have a '97 427 kit that I purchased complete. Since the front wiring harness (blinkers) has developed a short. Does anyone know where I might get one of these, as my builder has said that Classic has had it on back order for almost 18 months(?).
Old 02-17-2003, 04:08 PM
xlr8or's Avatar
If you can't get what you are looking for just go get a Painless Wiring harness and install that. No sense in messing with a messed up harness when you can fix it for 300 bucks and about 12 hours install time.
http://www.painlessperformance.com/
I have installed several of them in different cars now and never had a problem.
Scott
Old 02-17-2003, 05:22 PM
petek's Avatar
Cobra Make, Engine: CRL, 351W, Tremec TKO
Wiring does just go bad. Connections go bad. Wires go bad only when they are rubbing against something, etc.
If the rest of the wiring is ok, why not just troubleshoot the problem and replace only what is needed?
What are the blinkers doing / not doing?
Pete K.
Who is John Galt?
Old 02-21-2003, 02:15 PM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
Don,
I finally figured it out 121 wire in one side of starter button from ingnition switch and 121 and 126 on other side of starter button
then 126 to solenoid. It turns the starter with out 126 and 121
being connected out on engine???. I bought a starter for a 351 engine. Do I need a different starter due to the bell housing for the Tremac?
