Old 07-20-2003, 12:56 AM
Unhappy Don or Dv...can you help!
Hey Don and DV! I've got a problem. I've got the Mustang II front end and when coming home from a ride. I heard a nose from the front end. After getting home I found out that I lost the screw/washer and rubber top of the shock on the passengers side. I went back to were it happened and found all the parts...that was great. But I noticed after that the passengers front spring is broken...must be the bad roads here. Can you help me out!!
Thanks.
Snake/Gerry.
P.S. I will one day change out the front and rear suspention..but until then I need either one spring to fix the problem or two, to make them even and the same.
Thanks Guy's.
Old 07-20-2003, 05:13 AM
Double Venom's Avatar
Snake,
You gotta tell us what spring you're running. CR's originals, coil overs, standard upgraded springs?
DV...
Old 07-20-2003, 06:54 PM
Hey DV! I'm running the Mustang II 1978 coil springs...cut as the manual said, 1 1/2 coil removed...I found the front end to be a little rough...front end likes to bounce/travel when hitting consecutive bumps...I guess that's what you call bump steer/travel. I'm not using the front or rear sway bars.
Thanks.
Snake/Gerry.
Old 07-21-2003, 07:52 PM
Send a message via AIM to nolimits
Hey Snake,
followin up for DV...
Good plan to replace both springs. Better safe than OH $#1T!We can supply you Blue Coils (Sus. spring specialist inc.) that don't need to be cut for $55US ea. + the int. shipping. Sounds like your shocks are being punished too so decide whether to invest now or hold out for the coilover upgrade.
Feel free to give us a call. We'll set you up with the right spec.
Jay
Classics by Elite
740-852-5280
"If at first the idea is not absurd, then there is no hope for it." A. Einstein
