Old 09-28-2003, 04:21 PM
Question Door
Any idea where I can obtain the right and left inside door openers? As I said in my first message, I just got the car and as I go though it (trying to finish it) some things are missing, ie., door openers. Thanks in advance for you input. Will post some pics as soon as I can.
Old 09-28-2003, 05:51 PM
Fox's Avatar
Fox Fox is offline
Cobra Make, Engine: 302 done, CSX289 comp body, leaf spring chassis to original specs...
Donald,
Try:
Finish Line at cobraaccessories.com
Cobra Restorers Ltd at cobrarestoreres.com
Europa at cobraspares.com
You will find that parts such as these aren't always maker specific.
I look forward to you project up-dates and the pics.
-John
So you been broken and you been hurt, Show me somebody who ain't
Yeah I know I ain't nobody's bargain, But hell a little touchup, and some paint...
Old 09-29-2003, 08:35 AM
Thanks for the web sights. I'll take a look.
Old 09-29-2003, 02:26 PM
Double Venom's Avatar
Don,
Just what "door openers" are you referring to? The Finish Line door latches, are not made to work with a CR's.
Explain what you need and I will make sure they are sent.
DV...the problems are going away!
Old 09-29-2003, 05:44 PM
Fox's Avatar
Fox Fox is offline
DV-
My bad. I did not notice I was in the CR forum when I responded to Don. I meant no disrespect or misinformation.
-John
Old 09-29-2003, 06:13 PM
Fox!
Man..no sweat fella! I just couldn't figure out if he needed the "mechanicals", the strikers, or the bear claw latches themselves!
Don has since sent me an e-mail describing what he needs. May take a few days, be we'll get him on the right track!
DV...no problem that can't be fixed with a bigger hammer!
Old 09-30-2003, 09:49 AM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
The door openers, and hood opener are modified bicycle handbrake levers and cables. A little mickey mouse, but they work.
Somebody has developed a better way of opening doors on a CR.
Old 10-02-2003, 05:56 AM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
Default door openers
Go to Bethania Garage Inc. I installed these on my CR.Positive action and no stretched cables. Look in my picture gallery for diagram which shows installation and how they work
Old 10-05-2003, 07:57 PM
Thanks for all the suggestions. I finally found the openers but decided to install electric openers. They work just fine.
