Old 03-26-2007, 11:34 AM
Default Transmission Mount ??
What transmission mount, or part number, does a 1992 Classic Roadster use??.
I have a 351W, mated to a Richmond 5-speed.??
Thanks
Old 03-26-2007, 02:21 PM
Jimi G's Avatar
I have Tremec transmissions, but I would imagine the mounts will be the same, your best bet will be the polyurethane mount from Lakewood. The part number is 24351 most performance shops will have it in stock. jimig@standardtransmission.com
True friendship is like peeing your pants, everyone can see it, but only you can feel its warmth.
Plan your life like you will live to be 120 years old...Live your life like you could die tomorrow.
Old 03-26-2007, 03:44 PM
Do you have polyurethane motor mounts? If not, I've heard that it's a bad idea to use poly trans mounts....
Old 03-26-2007, 04:05 PM
Just the stock motor mounts I suspect. Is there a special transmission mount for Classic roadsters ??
