Old 10-21-2003, 08:28 AM
tabester's Avatar
Default Transmission Cooler to fit in lower scoop
Does anyone know where I can get a cooler to fit in the lower scoop for use with an automatic transmission. I'm running a 302 with an AOD 4-speed.
Old 10-21-2003, 11:07 AM
Mr.Fixit's Avatar
You can use the exact same type and size of cooler that most guys use as oil coolers. I have done this before, it keeps the correct appearance in the front end.
Tabester,
Jegs Mail order cataloge has B & M Hi Tek street rod trans cooler for 45.99
Polished aluminum 11 wide, 4 1/2 high 1 1/2 thick. I am running one of these on my Hunter with 390 and C6 and it works great. Looks almost like original engine oil cooler. I put a shroud over top of it and used braided line and Russel fittings to hook it up to hard steel line. Summit also carries this cooler.
exrodder
Old 10-21-2003, 11:58 AM
tabester's Avatar
Thanks I called Don and he said the same.
Kirk
