Old 10-23-2003, 11:20 AM
coosawjack's Avatar
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
Default Relay Switch??
Don/Ed...
Do you guys have the wiring diagram for the therostatic switch with a 30A relay for a Spal fan??
I have the manual switch working fine but found a place for the thermo switch and would like to use it and have the manual one for an "override"
Thanks,
Jack
Old 10-23-2003, 02:35 PM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
Jack, this is the way I wire the relay.
The relay terminals have #'s 30, 85, 86,and 87 stamped next to them.
#30 goes to the positive terminal on the fan. Run the other fan wire to ground.
#85 connects to wire 151 or an ignition power wire.
#86 runs to the temp sender.
#87 runs to the circuit breaker power side or direct to the battery.
To hookup the over ride switch, remove wire 161 from the switch and replace it with a ground. The other side of the switch has wire # 157 which you can hookup to terminal #86 on the relay.
Wire #151 and #157 run along the drivers side frame rail close to the upper control arm.
Don
Old 10-24-2003, 03:20 AM
coosawjack's Avatar
Thanks Don!!! That'll make it easier than the ole "Hit-n-Miss" procedure!!
I have the instruction sheet that came with it somewhere....Must be in a well guarded place cause I CAN"T FIND IT!!!!
How's CR-II coming along??
Good Luck!!
Thanks Again,
Jack
Old 10-25-2003, 02:15 PM
TC Cobra's Avatar
Cobra Make, Engine: Classic Roadsters; 351w, Crane Cam, AFR 185's
Hey Don!
Where do you like to mount the relay itself?
Thanks,
Dwain
Old 10-27-2003, 07:40 AM
dscott's Avatar
Dwain, anywhere that's good for easy access. I either mount it on the left front fender liner or under the dash on the passenger side.
Don
