06-12-2004, 11:12 AM
MN
Cobra Make, Engine: Classic Roadsters; 351w, Crane Cam, AFR 185's
Which Air Cleaner?
Hey Don!
Which round air cleaner should I use?
Max diameter, height?
The 13" chrome Motorsports unit is the look I'm after but I have a feeling it is too large to fit under the hood/scoop.
FYI: I've got a 351W, dropped mounts & 650 Speed Demon.
Thanks!
Dwain
06-12-2004, 12:58 PM
Cobra Make, Engine: Classic Roadsters, 302->351
Mine's a 9" diameter (2.25" high) that seems to fit just right into the scoop (I've got a 351 using the old (tall) mounts - I've got a set of the drop mounts from Don, but haven't installed them yet).
Good luck, and hopefully you're on a first-name basis with the guys at auto-pep-zone-boys!
JLW
06-13-2004, 08:46 AM
MN
I use the 10" chrome one from Ford. It does fit but be careful with the Ford wingnut they send with it. You may need to toss it and just put a small nut on it.
Don
06-13-2004, 08:52 AM
MN
Thanks, JLW and Don!
Don, what height element do you use?
Dwain
06-14-2004, 08:11 AM
MN
Dwain, 2"
Don
06-29-2004, 09:31 AM
OH
Cobra Make, Engine: Classic Roadsters, 393 stroker, Tremec 3550, about 425 hp, MDA GT40 289
Hey jwinkler,
Pay close attention to the old motor mounts before you take them out. I put my new ones in 1 1/2 years ago and had them reversed because the L and R stamps were switched on the parts. DV told me that a couple of runs of these slipped out. Just look closely before making the switch. Could save you from pulling the motor twice.
Jim Downard
Man, it would've been helpful to know that cop was behind me a minute ago!
06-29-2004, 01:20 PM
Don,
You're right about the wingnut - I ground mine down a bit for a "custom"
fit and no more problems. You supplied the engine for mine in '99.
Flip
Flip
