Old 12-01-2004, 05:11 AM
coosawjack's Avatar
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
Default Electric door latches???
I'm going to install Watson's solenoid door latch openers and wondered where the preferred location of the button is.
I thought about behind the door inside but the instructions say it is better to locate them on the door or hidden under the dash??
Where should they be....Need your experience before I screw up!!
HELP Don & DV!!!!
Coosawjack
Old 12-01-2004, 07:20 AM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
coosaw, I usually put them behind the door but you can put them wherever it's right for you.
Don
Old 12-01-2004, 07:31 AM
coosawjack's Avatar
Thanks Don....
That is where I thought would be best.
Jack
Old 12-05-2004, 04:20 AM
coosawjack's Avatar
Installed the solenoids and switches this week and ....BOY IS IT NICE NOT TO FIDDLE WITH THE LITTLE LEVERS ANY MORE!!!
These should be included in all kits.....
Jack
Old 12-05-2004, 06:00 AM
Double Venom's Avatar
Coos...
Sorry to take so long but I just found this thread. Too late for my 2-cents worth, but, you know me!
I mount the solenoid itself upside down just above the latch. This way it only takes a short cable and pulls directly upwards.
I then use "four" very small pressure type switches, one under the rear cowl, under the carpert. This lets you stand on the outside of the car and lets you hold onto the cowl-right behind the seat- in a natural motion then just squeeze. No one can figure out how you opened the door.
The other one is buried under the dash cover and just a touch will pop it when your sitting in the car.
Or... I've used 1/4" square topped switches mounted in the dash, left and right to open either door from the inside.
OK...maybe a nickels worth, Congratulations, you will love em even more as time goes by.
DV...Yep, that's a good thing!
Old 12-05-2004, 06:15 AM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
Where do you get the Watsons? Are they the most recommended? Sounds like a great idea.....thanks, Earl
Thanks DV for the quick response.....
Safe Flyin, errrrr Drivin, Earl
Old 12-05-2004, 06:43 AM
Here you go Earl,
They're right on the front page.
DV http://www.watsons-streetworks.com/holeshot.html
