Old 12-19-2004, 08:47 AM
Don Don is offline
Default Front End Shake
Don, there is another Thread regarding front end shake
http://www.clubcobra.com/forums/show...761#post534761
I mentioned that I have never experienced the problem on my CR. Bob asked, if I have a " rag joint "
Your help with an explanation, when you built the CR the spec sheet I obtained from the original owner mentioned a GM tilt column.
............thanks
Don
Old 12-20-2004, 09:09 AM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
Don, I don't use a rag joint. I use a solid shaft with u-joints at each end to connect to the GM column and rack. The rag joint is usually a leather or rubber cushion between the rack and the steering shaft. It does help eliminate vibrations and steering wheel shake. Flaming river sells a joint with a vibration dampner built in. I have found that most of the time the problem is in the wheel balance and the alignment.
Don
