Old 05-31-2005, 04:45 AM
dpmtrspts's Avatar
Send a message via AIM to dpmtrspts Send a message via Yahoo to dpmtrspts
Default Front Brake Hose
I'm a first time builder, building a kit I purchased from a friend. I have run into a problem with the front brake hoses. I have the GM caliper kit, but the metal sleeve on the brake hose hits the front coil spring. Has anyone had this problem and if so how can I go about fixing it?
Thanks in advance for any help!
Old 05-31-2005, 12:33 PM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
The brake hose you need does not have a metal sleeve. You will need the hose from a mid 80's GM metric caliper. It sounds like the hose you have is for the Mustang II caliper.
Don
