Old 08-10-2006, 09:10 AM
CobraEd's Avatar
Default Plastic toggle switches
Don, My dash has cheap plastic toggle switches. I want to replace them with some good metal ones. I see lots of "on-off" toggles, but none that I can use for the headlights that has three positions for Off-Low beam, High beam. Do you have any places to go to get three On-Off and one headlight switch. Or, . . . do you have them and can I just mail you a check?????
thanks
________
________
Old 08-10-2006, 11:10 AM
dscott's Avatar
CobraEd, the only other type of switch I use other than the plastic type is a metal pull switch. Similar to a headlight switch. Other than that I don't know of anything. We stock the metal pull switch.
Don
Old 08-10-2006, 11:23 AM
Cobra Make, Engine: MIDSTATES, 408C
Try Del City. They have cheap to expensive and a broad selection.
Service is exceptional.
Bob T.
Old 08-10-2006, 11:58 AM
Cobra Make, Engine: shellvalley 428 ford
Ron Francis has them as well as Carquest. Here locally so does Westlake hardware. Painless does as well I think.
Good luck,
Byron
