Old 10-01-2006, 11:01 AM
Smile little questions...
Hi everybody,
I'm the owner of a manufactured 1991 Classic Roadster, and I've questions for you :
1) What type of dise brake system can I use, (what mark) ? because I need to chang my dises and brake pads. I precise that I've got a 9'' Ford rear end.
2) Don't you think that 1991 CR have tendancy to heat ? Is it due to the original radiator and radiator fan ? What do you think about this, or have you got some advice ?
Ciao from Paris,
Thanks, bye
Domi
Old 10-01-2006, 11:35 AM
427SnakeSC's Avatar
Cobra Make, Engine: Shelby CSX 4995, Keith Craft built 427 SO
Send a message via MSN to 427SnakeSC Send a message via Yahoo to 427SnakeSC
I have a '91 Classic Roadster also. I recently replaced the thermostat and I am having over heating problems, too. I may have to replace the 180 with a 160. I have bled the air from the system, but still have a fluctuating temp.
"The 427 Cobra is easily the highest performance car ever sold for street use. A decent 427 - not the worst, not the best, will go from zero to 100 mph and back down again to zero in less than 14 seconds. All thing considered, you can put together a pretty good argument that the 427 Cobra is the ultimate performance car, judged on any basis you want to name." Taken from; Corvette, The Sensuous American
Old 10-02-2006, 08:12 AM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
Domi, there are several brake kits available for the front and rear of your car. Wilwood makes an excellent setup as well as many other companies. Do you have a price range you want to stay within. You also need to make sure you have a 9" and not an 8.8 rear. That makes a difference in what you order.
If you have a cooling problem when the car is in traffic or moving slow that is the electric fan not moving enough air. If you have a problem when running on the road at speed then the problem is radiator capacity. We Changed to Griffin aluminum radiators with a larger capacity years ago. We also changed from the old black magic electric fans to Zirgo. They work great and will cool up to 450hp with no problem.
Don
Old 10-02-2006, 01:48 PM
Size:  37.5 KBOK Don,
But what I want know is : what type of brake pads do I have, how can I find it, could you tell me, I send you a picture if it can help you ?
Old 10-02-2006, 02:55 PM
dscott's Avatar
Domi, It's hard to tell from the picture. Can you send me a picture of the front and back side of the caliper. My e-mail is don@classicroadsters.com.
Don
