November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-05-2007, 05:08 PM
Default new build
my cr kit was purchased in 1999 , i'm using a ford 8.8 rear end with factory disk brakes. up front i bought the brake parts from eci. wanting to use true knock off wheels. need to figure offset and wheel size and tire size combo to not stick outside of body.
Old 04-06-2007, 11:17 AM
MaSnaka's Avatar
Hey Brown, I can't answer your question directly and I know Don has been under the weather and maynot be responding to posts presently although I really can't speak for him. If you look through past threads here in this forum, do a search, you should find all kinds of specific info regarding wheels, tire sizes and offsets. Just about everything has been covered at one time or another, but I'm sure there is always something new to add. Good Luck, John
Old 04-07-2007, 12:04 PM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
What size wheels are you thinking about (15",16",17") and what brand? The stock wheel size is 8" on the front with a 3.75" backspace. On the rear I use a 9.5" wheel with a 4.5" backspace. You need to pick a brand you like and then find out what width they come in. Then I can help.
Don
Old 04-07-2007, 10:09 PM
JAC's Avatar
JAC JAC is offline
Cobra Make, Engine: Classic Roadsters II
Don ordered my wheels for the rear end I got with the kit I ordered from him. They stuck out the 1 1/2" from the wheel well that the new 8.8 rear ends with disc brakes are wider.
Measure your own so you won't get stuck with the wrong backspace. Just my 2 cents.
"COBRA" Big kids gokart
