November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-08-2007, 07:00 AM
Cobra Make, Engine: Classic Roadsters,351w B/S to 427 w/Hilborn Injection, Viper T56
Default Need a Steering Column....
So I've moved and my cobra is now out of the storage unit and back in my garage! Now I need a steering column. I talked to DV a long while back and planned on getting the GM column but now Don recommends the Ididot. Just wondering what the best option now is for getting a column for my cobra. I really only want the turn signals and maybe the brights on the column, everything else on the dash.
Old 06-08-2007, 11:04 AM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
Don's right Ididit is the way to go!
Old 06-08-2007, 11:08 AM
Do you know what Ididit column is the correct one for the CR? They seem to sell dozens of different columns and alot of GM type columns.
Old 06-08-2007, 01:04 PM
onefastmustang's Avatar
Cobra Make, Engine: CRII with a Stroked Windsor
I went through my filing cabinet.. I have ididit part number 1120300010.
It can be found here..
http://www.ididitinc.com/steel_chrome_tilt_column.html
Although I have to admit that a tilt wheel is pretty usless in this car. at least for me.
Old 06-14-2007, 10:00 PM
I got my Ididit column... Thanks! I have a question about installation if anyone can help. I have the 2" hole drilled in the firewall. Does the column get attached in any way to the firewall or does it just pass thru the hole? With the Ididit column, do I still just attach it to the cowl bar using the brackets that came with my kit? The manual is for the Chevette column so I just wanted to make sure the installation was the same for the Ididit.
Old 06-14-2007, 10:24 PM
I used an L bracket and a mufller clamp to attach it to the master cylinder housing on my brakes. Otherwise you run into an issue with it being sloppy.
Old 06-15-2007, 05:20 PM
OK, What mount do I use to attach the Ididit to the cowl bar? Don mentioned in a post to petek that it requires a different mount but is it a CR part or an Ididit part?
Old 06-15-2007, 06:54 PM
I ordered my mount from Pete Johnson at CR.. It needs a bit of tweaking once you get it, or at least mine did. But it works great.. It wasn't a whole lot of money either.
Old 06-15-2007, 07:25 PM
I bolted a 1/2 inch steel plate to the cowl bar and then used a stainless steel muffler clamp to bolt steering column to the cowl bar then a universal muffler hanger to tie it to the mastercylnder. The rubber in the hanger absorbs shock and holds the column secure.
