January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 07-27-2007, 11:18 AM
MDN MDN is offline
Default Main circuit breaker.
Hello all,
Can anyone tell me what the amperage is on the main breaker? I have a 94 CR, the breaker is mounted on the firewall.
Thanks,
MDN
Old 07-28-2007, 11:08 AM
I am not sure what breaker you are talking about. Do you have a manual? If not I can make a copy of the wiring diagram pages on Monday at work, scan them and send you a .PDF file or I could fax them to you. You could also post this question on the CRII web site and Pete or Don can get the info to you. http://www.classicroadsters.com
Terry
Old 07-28-2007, 12:04 PM
MDN MDN is offline
Hi Terry,
Thanks for your reply. I have a manual, on page 3-65 the first sentence says"connect wire 110 to battery side of circuit breaker power...". That's the breaker I am talking about. I don't know what the amperage is on the breaker. I would like to replace it with a manual reset breaker but I don't know of what amperage. I will post this on the CRII web site. Again thanks for your generous offer to help.
Regards,
MDN
Old 07-28-2007, 07:31 PM
MDN,
My 110 wire has a 30 AMP fuse coming off of it. My car was origionally factory built but I do not know if someone changed anything. I would still contact CRII and check with them (just in case). Hope this helps.
Terry
Old 07-30-2007, 08:40 AM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
The breaker is 2-30 amp breakers tied together. We have those in stock if you need one.
Don
