Old 10-17-2007, 07:31 PM
Default zirgo fan attachment
I bought a Griffin radiator setup from CRII. It came with the Zirgo fan. It did not come with any brackets to mount the fan to the car other than the plastic slide in pieces for the fan. Is anyone using the same setup? Any pictures on how you mounted the fan? Any ideas?
Thanks in advance.
Terry
Old 10-18-2007, 08:30 AM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
Terry, position the fan as low as you can on the radiator for hood hinge clearance. You can use the plastic mounts by attaching them to the top and bottom rail on the radiator. Just drill 4 small holes and use machine screws and nuts. You can trim the plastic mounts to fit since they have multiple holes for mounting.
Don
Old 10-18-2007, 09:01 AM
Thanks Don. I had the fan turned 90 deg the wrong way. The tabs were horizontal not vertical. Will check it out tonight.
Thanks again,
Terry
