| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
04-30-2008, 11:41 PM
IL
Cobra Make, Engine: Ford 460 Cobra Jet
gas tank straps
i have a 1996 427,do the gas tank straps pull all the way up to the frame?
05-01-2008, 03:07 AM
Mi
Huckelberry5,
With the insulation on the straps, tank in place and the straps bolted to the frame their is a minimal amount of space left. This is for expansion of the tank when full. Answer your question?
DV
PS= you are talking about a CR's Cobra-no?
Reason: PS
05-01-2008, 06:02 AM
IL
yes thank you
05-01-2008, 09:59 AM
CA
Are the gas tanks standard issue on the CR's? Capacity? Sending unit?
John
05-25-2015, 12:21 PM
Oh
Cobra Make, Engine: Classic427 351w
John
I just put 12.2 gallons in my '92. Guessing 13-14 gallons?
05-25-2015, 07:20 PM
TX
I got my kit in "99 and the tank capacity is 19 gallons, and it came with the
kit. The sending unit only makes it to 1/2 full on the gauge so I watch the
odometer more than the gauge.
Flip
05-01-2008, 10:54 AM
Mi
Normally7 ?
DV
PS Don may have changed this???
05-01-2008, 01:32 PM
CA
Mine is 10 to maybe 12 gallons. Sending unit is worthless so I have no idea how much fuel I have. So I always feel the need to fill 'er up.
John
05-26-2015, 12:04 PM
UK
Cobra Make, Engine: Kirkham #523, 427 S/O
John
10 to 12 gallons seems a ridiculously small tank for a Cobra. You must spend half of every trip stranding at the gas station.
I've just replaced my standard Kirkham tank, which I think was around 30 gallons with the original style 42 gallon tank, which will come in very handy for my road trip to Italy in September.
Paul
05-26-2015, 11:48 AM
CA
Ohio Ken,
That post is 7 years old but thanks for the response...finally, just kidding with you. Since then I have run my car out of gas and it took 14 gallons to fill. Also I found that a lack of a good ground was preventing my gauge to work properly. Apparently incidental tank to chassis contact causes a gauge to read erratically. A proper ground between the tank and chassis solved that problem.
19 gallons sounds good.
Thanks,
John
05-30-2015, 05:19 AM
Oh
Ohio Ken,
Thanks,
John
Oh my...I feel like an idiot replying to a 7 year old post lol... I need to check dates more closely! Then again, the info is always helpful regardless.
