| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
05-16-2008, 05:12 AM
IL
Cobra Make, Engine: Ford 460 Cobra Jet
LeMans filler
any tips tricks or hints for installation? I have never worked with fiberglass.
Thanks
Robert
05-16-2008, 09:23 AM
Mi
Robert,
Have you worked with "Marglass", or Duraglass type products?
DV
05-16-2008, 09:54 AM
Tx
Cobra Make, Engine: Classic Roadster, 408 LSX
Did anyone ever find a source for the spillage well? It would be nice if the new owner of CR would change the mold to include that like most companies.
I guess that wouldn't help me though.
Greg
I've spent most of my money on cars and women. The rest I wasted.
05-16-2008, 10:09 AM
IL
No I have not DV
05-16-2008, 11:19 AM
Mi
Greg,
The CR Cobra takes two different gas caps. A spillage well IS included with the Lemans option. Problem arises when guys buy from Finishline, etc., they do not have spaillage wells for the CR.
OK, Huckelberry, how about body filler? If not feel free to call me and we will have a 1/2 hour class in installing the well with the proper material. No big deal at all!
DV- 231-869-4608
05-16-2008, 03:24 PM
IL
ok went and bought a fiberglass repair kitand short strand fiberglass filler. A support was broke on the underside. So I fixed it. I think i did it right because the cat is still stuck there!!! I could still use any tips or tricks
Thanks
Robert
05-16-2008, 03:56 PM
Mi
OK, first thing in thte morning-full instructions. Have you glassed in the well yet? If not, hold off.
DV,
05-17-2008, 05:52 AM
IL
no I have not glassed the well yet.
Robert
05-17-2008, 01:54 PM
Mi
OK, sorry I couldn't get on CC earlier!
Now: FILLER/SPILL - LEMANSWELL 101;
First take the Well and fit it from underneath. The notch or extra lip on the well should line up with the inside corner of the trunk wall. It will find a "natural" spot to the fender when the notch lines up with the trunk. Take a crayon, magic marker, what ever and outline the edge on the inside of the fender. Grind the fiberglass where ever the well lines up, not a lot just clean it up a little, even 36 or 80 grit paper will work but I use a small grinding pad.
Take the well and drill a 5/8's to 1/2" hole dead center of the well. Grind all the edges down on the outside edges of the well. Again 36 or 80 grit or small grinding pad.
Take your drill with you and just place the well in place from underneath, using the center hole in the Well drill right straight up through the body using the 5/8' or 1/2" drill.
Find one of you threaded bumber rods, screw a regular nut to it about two inches up, insert this rod through the Well then with a large washer first put a nut on the bottom and tighten the two nuts up.
Have a small block of wood or something similiar, drill a hole through it big enough for the rod to go through. slide the block of wood over the shaft and install another weasher and a nut. Once you have this done, take the upper portion i.e.; block of wood, washer and nut off, leaving it handy.
There is a reason for all this!
Once the Well is ready with the bottom bolted tight, now get your body material mixed. Mix enough to get real sloppy around the top of the Well. Put the filler all around the edge, thick-now immediately push the rod up through the hole in the body with the Well now touching the inside of the fender. Push it up tight. Need a helper? Get one first.......OK the well is in place with the rod sticking through, add the block of wood a washer and a nut......Tighten it fairly tight making sure there is no gap between the Well and the fender. What you have done is to make a "sandwhich which will hold the Well in place without movement until the filler drys.
Take a few minutes rest while the filler gets totally hard.
Now very carefully cut out the fender to the inner edge of the Well, from the top of course.
You can now cut the center of the Well out (using the open Lemans Cap as a template.)
Now its time to fiinish it off! IF your gas cap hits the edge of the Well (To be a painted surface) add about a full 1/2" of filler to the entire bottom of the Well. Put it in as smooth as possible and if you have a 6" DA you can then just finish it off with that. Fill in the eges of the fender and the Well and get out the primer!
Now you should have a LeMans Gas Cap Well in place.
I'll be waiting for an update or questions!
DV
05-22-2008, 05:41 AM
IL
DV worked great. I dont think it would move even with a stick of
dynamite!!!!!
Thank you
Robert
05-22-2008, 06:22 AM
Mi
Huckelberry5, Robert-
Fantastic, and thanks for letting me know!
DV
