Like Tree1Likes
  #641 (permalink)
Old 12-08-2008, 12:47 PM
Double Venom's Avatar
Geesh, we are already over 2' ! Michigan ski lodges are setting all new records one after the other for the earliest starts they have ever had!
Oh-well, I told the wife when I retired she could move anywhere in the Continental U.S..
Here we are in Gods & long-john's country!
DV
  #642 (permalink)
Old 12-08-2008, 05:57 PM
capteddie's Avatar
Send a message via AIM to capteddie
DV
The bumper tubes were waiting for me when I got home tonight.
Very, very, very nice
They look great!!!! Nice job!!!
"the other ed"
  #643 (permalink)
Old 12-11-2008, 05:56 AM
capteddie's Avatar
Any sign of those new bender dies, DV? If not. I'll give them a call in a couple of hours.
Here's a quick list of what I'm bringing over after the first of the year.
1) new wider rear tires
2) a sheet of mesh screen for the front vent inlets
3) template for the speakers
4) 1 more 2" roll bar bezels. You have 3. I picked up the 4th.
Anything else we need?
Cheers!
"the other ed"
  #644 (permalink)
Old 12-11-2008, 06:46 AM
Not that I can think of. UPS halted all delivery's in our section of the State (massive snow) until yesterday. Looked like Christmas yesterday but no dies. Maybe today?
DV
  #645 (permalink)
Old 12-11-2008, 06:48 AM
capteddie's Avatar
DV
OK. I'll see if I can get tracking info and give you a heads up on the status.
"the other ed"
  #646 (permalink)
Old 12-11-2008, 08:08 AM
capteddie's Avatar
DV
The dies are at least another week out, before delivery. I don't think theirs a rush to get them anyway.
"the other ed"
  #647 (permalink)
Old 12-22-2008, 03:04 AM
Only a Christmas present if your a "Cobra" guy!
Merry Ho-Ho from the land of Down under (snow!)
A true 2" DOM seamless 4-point roll bar for a CR's Cobra.
Next stage is a black highly finished powder coat....
  #648 (permalink)
Old 12-22-2008, 04:15 AM
capteddie's Avatar
HOLY $H!T DV!!!!!!!
WOW The bar turned out great!!!! Man that looks really good!!!!
Thanks for the pictures!!!!
"the other ed"
  #649 (permalink)
Old 12-24-2008, 03:15 PM
capteddie's Avatar
DV
According to tracking info. The additional dies got delivered. I hope they are the right ones?
Merry Xmas!!!! See you on the 3rd!!!
"the other ed"
  #650 (permalink)
Old 01-04-2009, 09:34 AM
Default Case of the 'ANTI-SPINNING' Cobra Air cleaner
How many of the large Cobra air cleaners that I have installed all "spin" under load knicking up the paint on the inside of the hood intake?
Well, not any more! I think cpteddie will even be surprised by this one.
Phase one: Holley mounted carb, remove the bolts and the studs holding them on, use a 5/16's threaded rod, locktite the rod and the new "flange nuts" in place:
Phase Two: 3/8's aluminum tubing (fueline) cut to fit the studs- Must look pretty when done .
Phase three: Studs covered, base plate attached with "flange nuts".
Phase Four: The end of the headache of the Spinning Air Cleaner- you can take both hands and try and get it to swing- "Ain't gonna happen!" $5.00 in material-one hour of time- piece of cake!
A long time problem cured- cheap and easy!
DV
  #651 (permalink)
Old 01-04-2009, 09:57 AM
Mac VABCH's Avatar
Cobra Make, Engine: BDR #250
How simple why didn't I think of that. I have been fighting this for years.... Thanks for the tip.... Mac
  #652 (permalink)
Old 01-04-2009, 01:09 PM
James Stern's Avatar
Cobra Make, Engine: Classic Roadster, 302, roller cam, Holley 650
DV, Your experience is showing again. Absolutely brilliant.
The one line never heard in heaven; "Gee, I wish I had spent more time in the office."
  #653 (permalink)
Old 01-04-2009, 01:21 PM
capteddie's Avatar
DV!!!
Thats even a better solution than what you and I were talking about yesterday. We had discussed just using 2 unused threaded holes in the manifold.
Very nice upgrade
Was good seeing you yesterday!!!!
"the other ed"
  #654 (permalink)
Old 01-04-2009, 01:57 PM
My breather is modified to push it back towards the firewall and clear the front lip of the hood opening. I used a single unused threaded hole in the centerline of the back of the manifold. Works great.
Terry
  #655 (permalink)
Old 01-04-2009, 02:22 PM
capteddie's Avatar
Terry
That's along the same lines as to what DV and I were talking about yesterday. There's probably a half a dozen different ways to keep these cleaners from twisting. DV doing the 4 point just makes our build just a little different from all the rest....
"the other ed"
  #656 (permalink)
Old 01-04-2009, 07:57 PM
I'd leave the nuts off or use nylock nuts. Don't want one of those buggers backing off and getting sucked into the engine.
  #657 (permalink)
Old 01-04-2009, 08:17 PM
Ronbo, et.al;,
The reason I specified "Flange Nuts" is that they will NOT back off. I guarantee you put one of those on hand tight you will have to use a wrench/socket to get them off! Especially since they are biting into fairly soft aluminum.
Nylocks wear out and are only verified for one use. If not serrated flange nuts, the studs have to be at least 3/4" longer. Not a big thing, but I have this thing about blocking air particularly in this instance. No an extra 3/4" stud with a bigger nut will not cut down that much velocity/volume of course, but with four in place it/they could cause a "vortex of air going into the carb" possibly creating a miss or stumble at high speed ? If it should think how long it would take someone to find it? New plugs, plug wires, rebuild the carb, check intake of fuel and passage to the carb, start with the electronics???
To answer a lot of your questions, "these" are true lock nuts & bolt.The heads are solid as well as the flange around the nut. No lock washers are necessary and are more of a hinderence. "Every" nut and bolt that I use in my builds are of this type hardware. Hundreds of cars and thousands of fasteners later I have never had one work loose!
Just my thoughts...
DV
  #658 (permalink)
Old 01-05-2009, 11:56 AM
capteddie's Avatar
Well crap DV!!!
Just rechecked tirerack.com and those 295s are only available in 50s.
So I guess we'll just run the rubber thats already mounted and switch to something wider in the rear next season. Maybe some MTs or a set of Goodyear BBs.
"the other ed"
  #659 (permalink)
Old 01-05-2009, 12:13 PM
OK,
Going to have the new/new ones picked up?
Not to worry on the bracket, I will now cut/weld it to fit tight to the new rear firewall. This will give you the room for low profile 17's if you ever choose to go that route!
Doing final 'glassing & body work on the rear firewall. Overall you have picked up at least four if not five inches front to back! You're not going to grow taller are you?
DV
  #660 (permalink)
Old 01-05-2009, 12:59 PM
Yep DV those should work. But since the studs are really there to prevent twisting and they don't hold the top down the nuts aren't really needed. I'm just a little anal about stuff inside the air cleaner.
A rubber base gasket as opposed to the paper one might also stop the twisting.
What the heck it's a Cobra, just safety wire it!
