Old 06-11-2008, 04:40 PM
Cobra Make, Engine: CR 347 ford
Default hood latches
Has anyone that has used the original type hood latches have the measurements as to the location of the holes? Also,did you use cams or latch type devices,and how did they attach?
Jagrolet
Old 06-28-2008, 12:47 PM
Cobra Make, Engine: classic roadster,408cu
Jag im right there now , i will have it figured out soon . Iam going with cam latches , maybe DV has some numbers. It looks like you will have to go in the center of the square brace in the bottom of the hood and centered on the corner gusset of the body.WD
Old 06-28-2008, 12:57 PM
capteddie's Avatar
Send a message via AIM to capteddie
I have no clue what the measurements need to be. But DV is at that stage with my car. He had me order cams for mine.
Here's the link for the cams http://www.finishlineaccessories.com...roducts_id=161
Ed
Old 06-28-2008, 01:26 PM
Double Venom's Avatar
If I'm allowed I will post pictures on how I do it and where-sorry if it's holding you up.
DV
Old 06-28-2008, 05:22 PM
WD,
I guess that you decided not to pin your hood?
Terry
Old 06-30-2008, 10:41 AM
Default to pin or not to pin ?
Terry I keep changing my mind mostly because I am not crazy about the rad mount hood support when body goes on I will decide , I may cut the rad support all up and make my own. WD
Old 06-30-2008, 12:39 PM
WD,
I am finding that my hood moves around a lot. If I was to re-do mine I would change the hood so that it hinged off of the body. My concern its that there is so much independant movement, the fiberglass is going to crash or crack somewhere.
That could be because I still need to take it down and have the wheels aligned. But I still do not even like the idea of the movement.
Terry
