Old 06-25-2008, 06:15 AM
Double Venom's Avatar
Default WD: Help an ol' guy out!
WD- Control arm bushings, as YOU know I need the rear bushing that goes into the rear end. I Gave FORD SVO the 5500# part nuumber TWICE and the guy sends the same as the front control arm bushing. "Much to small for the rear!" Call and talk to him and he insists the bushings are the same! I have explained to him numerous times that the rear bushing is at least a 1/4" thicker-he wont believe me or isn't listening. I tell him to take his $%#@ control arm use the same bushing he keeps sending me and put it in the 'front' hole and it will fall right through! The answer I get is " They are the same bushing I don't need to get another control arm and look at it."
As easy going as I am. if I could reach through the phone his eyes would fall out on his monitor from me squeezing his throat!
Now to get to the question, do you by chance have the number for the bushing that fits the large end / (rear end bushing) M-5500-A control arm?
DV-totally exassssssperated!
