Old 08-11-2008, 12:03 PM
Cobra Make, Engine: CLASSIC ROADSTERS 302
Default Windshield
Please Help, New At This, Bought A 1991 Cr Factory Built Car, With A Broken Windshield,found A Glass From Pikington Glass For $235 But Its For An Original Cobra Not A Kit,will This Fit.thanks:
Old 08-11-2008, 03:35 PM
jdean's Avatar
It should fit.
6th generation Texan....
Old 08-11-2008, 04:19 PM
VINCENT RUDI's Avatar
Cobra Make, Engine: ANTIQUE AND COLLECTABLEFORD 460
Put A Straight Edge Across The Interior Window Of Your Exsisting Glass And Mesure From The Straight Edge To The Window, Write That Number Down And Do The Same With The New One If The Numbers Are The Same You Know The Curve Of The Window Matches Yours, Now All You Have To Do Is Mesure The Hieght And Width And That Sould Anserw Your Question Good Luck With The Snake.
Old 08-11-2008, 04:38 PM
Double Venom's Avatar
Guys, not to be contradictive but the windshield Canea is talking about is for an ORIGINAL Cobra frame. It will NOT fit a CR's or ANY other kit car that I know of. All of the kits use the same manufacturer for the winshield and frame; ERA, FFR, CR's, B&B, etc., etc. I'm not sure but I think that even Kirkhams use this windshield? I'm sure Thomas or his brother will correct me if I am wrong on that one!
Hate to have a guy go out and spend good money just to have to do it again.
DV
Old 08-13-2008, 06:59 PM
Give www.finishlineaccessories.com a look or www.shellvally.com they will have what you want.
