Old 12-10-2008, 05:07 AM
coosawjack's Avatar
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
Default CR Tach
Anyone have a spare tach...mine is acting goofy!!
Coosawjack
Old 12-10-2008, 10:21 AM
Double Venom's Avatar
Coosawjack,
Do know what brand it is?
DV
Old 12-10-2008, 03:23 PM
coosawjack's Avatar
Ed,
Thanks for the reply!!
ALL of my instruments say "Classic Instruments" at the bottom of the face plates?? Does that help??
I will also take a new speedometer if you have one as this one is very fogged up inside!!
Coosawjack
Old 12-10-2008, 04:12 PM
Coosawjack,
Classic Gauges are their own company. If you do a google search you will find them with a phone number. As far as the speedo' fogging up.....turn on your parking lights! Only the most exspensive and fine gaugees are totally air/water tight. The fogging is quite normal due to humidity or moisture present. Turning the parking lights on for a while will heat up the inside of the gauge and dry out the moisture thusly fixing your fogging problem. Unless of course you have a tremendous amount of water getting into youir gauges!
DV
PS. Erratic tach- almost always ends up being a ground or the feed wire is getting crossed/stray electrical interference from speakers, hi-volume amperage bleeding across, etc. Do you have a radio? IF so can you hear a high pitched whine co-ordinating with your RPM through the speakers? Windshield wiper motors close to the tach wire can really raise havoc.
Old 12-12-2008, 04:36 AM
coosawjack's Avatar
Default Once Again.....Saved By DV!!!
Ed,
I called Classic Instruments and spoke with Fred who told me I could send both my tach and speedo in for re-face (both dials have yellowed numbers and foggy lenses) and upgrade if necessary!! They remove the bezel, re-face, calibrate and install new lenses for $35.00 each....WHAT a deal!!
BTW, I think my bouncy tach needle was a loose signal wire.....if not they will install a new movement for $30.00!!!
Great company!!
Thanks again DV....Merry Christmas!!
Coosawjack
Old 12-12-2008, 10:59 AM
Coosawjack,
Excellent and
Merry Ho-Ho to you and yours!
DV
