Old 08-19-2009, 02:32 PM
Default big block chevy sidepipe hedders
need to locate a set of big block chevy hedders, thanks jerry
Old 08-19-2009, 04:51 PM
vettestr's Avatar
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Hello Jerry,
To answer your question spot on I will need a little more information. If you are looking for headers that fit a standard bolt pattern of BBC heads and want them in sidepipe configuration I can help. Try Jegs or Summit for 1970 Corvette headers and sidepipe exhaust made by Hooker. http://www.jegs.com/p/Hooker/Hooker-...53672/10002/-1
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 08-19-2009, 07:51 PM
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
For what vehicle? If for a Cobra, just install the engine and have the hedders custom made, you're probably not going to find any hedders that will fit your chassis.
" It ain't no big deal"
Old 08-20-2009, 03:00 AM
Double Venom's Avatar
Tim is spot on, unless you find some one with a CR's with a Chevy BB, the chances of finding headers for it THAT FIT CR,s is going to be nil to -0. I of course could be wrong but it would be a rare bird.
Without a JIG or blueprints the fabricator is going to need your frame with the body mounted, the side-pipes, and most likely the engine in the frame.
There is one guy that I know of that may be able to help you, (Jeff- in Ohio. A CR's builder and fabricator does make headers) his number is 419-919-2277
HINT: Don't forget to tell who ever fabs them up for you the left front tube (#2 cylinder) has to extend out farther from the rest, so the steering shaft has enough room to pass through the headers.
If you were closer I'd make them for you.
DV
