Go Back   Club Cobra > General Discussion > Club Cobra Introduction Forum (introduce yourself)
Old 06-28-2009, 01:56 PM
Default Hello all
Hello,I am a new member and I am interested in buying a cobra.I have two vintage cars----- 1954 Austin Healey BN1 and 1957 Triumph tr3. I don't know much about cobras so any help as far as what to look for would be greatly appreciated.
Old 06-28-2009, 04:04 PM
ZOERA-SC7XX's Avatar
Welcome to the madness. Since you already have two 50's british roadsters, the Cobra is much the same, except that you will have a high horsepower V8 and big tires. Your gas mileage will also be a little less than your current ride. Good luck and stay tuned.
Old 06-28-2009, 05:03 PM
mrmustang's Avatar
Gold Star Contributor
What is your budget like?
Then after you answer that one what type of use are you looking to get out of it (IE: street car, daily driver, drag racer, canyon cruiser, road racer, or a nice Sunday driver)?
I've posted the following for the FAQ a number of times, read it, reread it and understand what you are getting yourself into before you spend any of your hard earned money on a Cobra (real or replica)
"How to buy a used Cobra"
Editors Note:
Ok, the first thing you have to ask yourself is "how much money am I willing to spend for a used Cobra", and what my usage is going to be. Now, by usage, I mean a either a daily driver, weekend cruiser, show car/trailer queen, 1/4 mile drag racer, road racer, or any combination of the above. Once you have set your budget and have a pretty good idea of what you want to initially spend, your next goal is to find the right car for you. Whether your spending $22,000, or $150,000 should not matter at this point, as I've personally seen beautiful, well built cars at $22,000, and some truly horrible cars with over $100,000 in to the build.
Your qualifications:
Know your strengths and weaknesses when shopping for a used Cobra, if you know bodywork, and not the mechanicals, take along someone who has a greater mechanical ability than yourself. Vice versa if your strengths are in the mechanical end of things, and not the cosmetics. Two sets (or more) of eyes are always better than one.
If your going to see a cobra in person:
What to look for:
Fit: How does the body sit on the chassis, do the doors, hood, trunk all line up?
Finish: How is the paint, are there runs, drips, sags. Does the paint have a nice shine to it, or does it need to be buffed out or stripped and repainted?
Interior condition: Does the interior show a lot of aging, do the seats need to be recovered.
Mechanical: Are there any leaks or drips under the car? What about the overall appearance, does the car look like it was well taken care of, or does it look like it was ridden hard and abused.
Engine: Again, any leaks or fluid drips, how does it sound (this can be tough on a car such as the Cobra). Check the engine warm, cold, at partial throttle and at idle. Make sure to check the temperature gauge once the car is warmed up and at idle. Also check to make sure the thermostatically controlled fan (if so equipped) kicks in when it is supposed to.
Transmission: Take the car out for a road test if possible (don't expect to let the seller to allow you to drive it), does the clutch work properly, does the transmission shift smoothly through the gears. Check for leaks here as well.
Rear End: Does the rear end clunk, leak fluids (check behind rear rims for signs of fluid, along with the front and rear of the differential housing)
Suspension: Check the bushings, do they look cracked and worn out, if so, factor in replacements to your costs. What about the shocks (coil overs or ???), if you ask the seller to push down on each corner, watch the rebound, if they bounce forever, then expect to replace them. If the car is equipped with coil over shocks, set the car on an even surface and see if the car sits level or not. if so, then the shocks do not have to be adjusted, if not, then expect a few hours getting things right.
Brakes: If you place your hand on the front disks (do this before the car has been driven), can you feel any grooves in the disk itself? Does the brake pedal feel firm when your sitting in the car, what about on the test drive, ask the seller to do at least one hard braking maneuver so that you can tell whether the brakes are adjusted correctly for the car. Some cars will have a combination of disks and drums, others will have four wheel disk brakes. If set up correctly, a disk/drum set up will work for all but the most extreme usage (IE: heavy road racing, endurance racing, etc).
Wheels: Are the wheels balanced, bolted on, or held on with knock off's? Bolt on wheels are a matter of personal preference, if you like what is on the car, great, if not, factor in a replacement some time down the road. Knock off's should be checked to make sure they are tight, if the knock offs and safety wired on the car, that shows a level of attention worthy of a good owner/seller....
Tires: Are the sidewalls cracked, are the DOT approved, radials or biased ply? What about the sizing, do the fronts both match? What about the rears?
Electrical system: Do all of the lights function, hi beams, lo beams, turn signals, brake lights, horn, etc? What about all of the gauges, do they read correctly?
If your buying a Cobra sight unseen:
Use the above as a reference guide as to what questions need to be asked. If the owner is forthcoming with detailed answers, then you can feel a little more comfortable in dealing with them. if the answers are a little more ambiguous and vague, then perhaps the owners is trying to hide something, or does not really have any mechanical ability or qualifications to answer the questions above..If this is the case, and your still interested in the car, pay to have the car professionally looked at by a qualified inspection service.
In closing, most of the above is all based on common sense. Don't let your emotions get involved in the decision whether to purchase one car or another. Also don't let other so called "experts" sway you to this brand or that, after all, it's your money, not theirs that your planning to spend..Finally, if you need assistance, or don't understand something fully, feel free to ask questions. __________________
I do hope you find this helpful.
Bill S.
Old 06-28-2009, 05:47 PM
Default Advice
Thanks for the advice.I can answer some questions now.Since I have three cars already this will not be a high mileage car.I would like to take it to work and back which is about 4 miles total.I am not going to race at all.I want something that I don't CONTINUOUSLY have to work on.That said,I am pretty handy with tools
Old 06-28-2009, 06:22 PM
cavedog57's Avatar
Cobra Make, Engine: NAF 427, 331ci, 4 spd, 3.55s
If you don't want to fiddle with it -- look into something w/ a (relatively) late model engine and fuel injection. Also four miles back and forth to work everyday will not provide enough time for the engine to warm up completely -- very hard on an engine. With a carb car expect fouled plugs. With any car expect more frequent oil changes and increased bearing and ring wear.
If you can't be good, be careful.
Dave
Old 06-28-2009, 06:32 PM
Seagull81's Avatar
Cobra Make, Engine: FFR3542K, 347 C. I., EFI, T-5, Miata Front Sway Bar, 3 Link, Red with White Stripes
Default Welcome!
Welcome to the forum. I might have missed it, but where do you live? There are Cobra Clubs all over the country. Hook up with the club near you and talk to them. They can help you spend lots of money and so can we. Send pictures when you find what you are looking for.
Take care and have fun!
Steve
Texas Cobra Club-Austin
July 2009 FFCars Picture of the Month
FFR3542K, 347, Holley Sniper EFI, T-5, 4 Wheel Discs, 3-Link, Miata Front Sway Bar, Red with White Stripes
Old 06-28-2009, 08:57 PM
welcome Bubby.....do your RESEARCH....and you will enjoy the drive to word(or past work) when you finaly get a Cobra
