November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 11-07-2010, 08:45 PM
SMOKNAC's Avatar
Cobra Make, Engine: SPF / FE428
Default New Superformance rear-end question? (Z1)
Just picked up MK111 superformance, has anyone out there put a big block fe motor in there car with
The new Z1 rear-end? I was told you mite have to shim the rear-end?
Just trying to find out if anyone has had any problems aliening the drive shaft?
Old 11-08-2010, 04:27 AM
Senile Club Cobra Member
I think it would depend upon what trans you are using. The shimming might only be needed if the output shaft center is much higher than the location of one with a TKO 500/600. As the chassis is designed for the shaft posistion on the TKO, something seriously different might cause driveline angles to require modification. I don't think a Top Loader would need any change.
rick@autoventureusa.net
