Old 04-26-2008, 11:30 PM
Cobra Make, Engine: Cobra International body Waltech frame
Default Seat Belts
Hello
I plan to not use a race harness style seat belt. Laws where I live are already touchy and that style tends to be a magnet if not ammunition for the police to pull you over as a potential speeder.
My question. I want a regular style with both driver and passenger pulling out from between the seats. See picture. With a "T" welded support system behind to weld to, what Ford model retractable is recommended? I've been told to use a style that shot out from the rear window deck. Like a Escort or Focus (non hatchback) Any Ford parts guys out there that can lead me right?
MV
"A company that makes nothing but money is a poor company" - Henry Ford
Old 04-27-2008, 04:16 AM
Ron61's Avatar
Post
Venamm,
Hard to see from the picture but I think the 1969 lap belts like came in my 69 Cobra would work. They have a retractable roller and bolt to the frame on each side of the seat. But I am sure that some of the newer belts would also work and most likely be better than those as they are old style.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 04-27-2008, 09:48 PM
Hmm....interesting. Now where to find a set.
MV
Old 04-28-2008, 02:09 AM
Maurice Butler's Avatar
Cobra Make, Engine: Scratch build, with help
Originally Posted by Ron61 View Post
Venamm,
Hard to see from the picture but I think the 1969 lap belts like came in my 69 Cobra would work..
In New Zealand they are trying to outlaw lap belts. In an accident with out a shoulder restrant they tend to cut you in half with major internal injuries, if you brains don't get bashed out on the windscreen or dash.
please think of lap diagonal as the minimum
Maurice
researching for scratch build
Old 04-28-2008, 06:49 AM
A lap belt isn't what I'm after. It is the pull down combo.
MV
Old 05-24-2012, 06:39 AM
Cobra Make, Engine: EM
Just bring this to the top.
Does anyone have any more info/examples on installing regular belts?
Old 05-25-2012, 01:31 AM
In the UK one of the most popular suppliers of belts (harnesses and retractors) is securon
Seat belts, seatbelt and harnesses manufactured by Securon for all vehicles and motor sport
- very helpful technical dept to.
Here are some pics of my Crendon with central seat belt mountings:
DSC00591 - Cobra Club Gallery
- but this is a static 3 point belt, although i am upgrading to retractors at some point this year. The bracket you see is part of a 'tower' that is bolted to the chassis directly above the diff. It enters the cockpit via a slot.
there are also some pics of the central mounted retractors on my old green car (a Pilgrim) - these bolted to a steel bracket embedded in the fibreglass. it was effective, but less aesthetically pleasing.
this also may be useful, pics of the Hawk arrangement, which is very similar to the solution used on AC MKIVs using inertia reel retractors.
Building our AC Cobra 289 LeMan » Installing Seat belt framework
http://www.the289register.com/stuart/Part%2013.pdf
http://www.the289register.com/stuart/Part%2026.pdf
HTH
Kevin
Crendon 427, in the making
http://crendonreplicas.com/
Old 05-25-2012, 05:44 AM
Cobra Make, Engine: v10 ford
Retractor seat belts are manufactured to suit the mounting position of the retractor reel. If the reel is on its back in a horisontal position the locking ball is in its lowest position so as to allow you to draw out the belt. therefor the mounting position and angle is what dictates what belt is suitable for your application. In effect if the reel is mounted at 45 deg you require belt A. If mounted at 90 deg to vertical then it is belt B If it is parellel then you need belt C. Therefor if you have the wrong belt for your mounting position you will not be able to extend it without it locking up. To sum up if you mount between the seats you will need a belt that will allow you to extend in the horisontal mounting. To find these belts you need to find a manufacturer or car model that has the same mounting position. Belt manufacturers will sometimes sell retail to the public as in Australia. Hope it helps, John.
Old 06-03-2012, 06:18 PM
BAsque1's Avatar
TRy SIMPSON Harness or Deist either one has several models that you could fit to your Cobra I have Deist and it has a Y shoulder harness and 4 point support.
Basque1
