Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Cobra's by Emerson----Speak with Bill Emerson
Old 08-05-2003, 10:44 AM
rdorman's Avatar
Renegade Nuns on Wheels
Default MG front end replacement
Mr Emerson,
Curt Scott mentioned to me that you did a front end for Gary Center's Unique replacing the MG front end and just how effective the results where. Myself as well as other older Unique, Arntz Butler owners would be interested in what you have available. There are a number of us considering the various options that are out there.
Are there pictures of the setup some where?
Thanks
Rick
OhioCobraClub.com
LondonCobraShow.com
Old 08-14-2003, 10:39 PM
Bill E's Avatar
Rick you should Talk to Tony Rippie we did his Unique. We start by removing the K member and cutting off the perches for the upper A arms the geometry is usually way off. We then instal perches that will accept a wider adjustable control arms whit bearings in them instead of bushings. This makes the front-end moor reactive and smoother. Next we set the strewing rack to the correct height to correct bump steer. Then we balance the rubber to the wheels and do a fore wheel alignment. This will eliminate any vibration in the steering wheel. cut down dramatically on cowl shake.
Bill Emerson
Old 08-15-2003, 05:46 AM
rdorman's Avatar
Default Thanks
Tony has spoken about this in the past. Is this a service that you would offer? Pictures?
Rick
OhioCobraClub.com
LondonCobraShow.com
Old 08-15-2003, 11:39 PM
Bill E's Avatar
Unfortunately I had a majeure computer crash and lost most of my pitchers.Im on the kids box right now. Yes, we could do some cars on a limited basis. Our work load is huge all reedy. We could not start one till about December,
Bill Emerson
