Go Back   Club Cobra > General Discussion > Consumer Watch
Old 08-12-2003, 09:26 AM
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
Default Engine info needed
For a 351 with med-hot cam, what will the initial advance be for a stable idle at 1000rpm? No vaccum advance only mechanical.
thx gn
Old 08-12-2003, 09:36 AM
RallySnake's Avatar
Niles,
I usually set it to 16 degrees BTDC. With 20 degress of advance on the centrifugal I'm at 36 at about 2500 rpm. Depending on the cam profile, the engine might start easier with initial timing set closer to 10 degrees BTDC.
Paul
HTML code is On
