Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Old 09-01-2010, 08:45 PM
Angry Koni Classic shock ...simple problem?
Hello All....I have a problem which I`m sure has been encountered before....I have a set of 4 Koni Classic rear Coil over shocks ( In the box) and a separate set of 4 X 250 Lb , 2.5" Dia , 10" Long Springs already Power Coated and guess what...The Springs mount on the shocks nicely but What do I use for the lower shock "Keepers" + Mounting Collar?. The shocks have the same body Dia as the stock XKE shocks and I could use the "2 Keepers" but I cannot use the Collar because the stock XKE Springs were a wider Diameter. What do I use??
Old 09-01-2010, 09:04 PM
1985 CCX's Avatar
Mike
My recallection is that the part you are looking for is a two peice unit that spans the shock shaft and spring. Hinges on the stop stabs on the base shock.
