Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Old 11-29-2010, 07:27 AM
mickmate's Avatar
Default Brake Master cylinder identification
This is bolted to the Jag pedal box in a CCX but is not the VW Beetle 113611015BH or the Beck Arnley 072301. Any body know what it is? Thanks.
mickmate
http://www.actoncustom.com/
Old 11-29-2010, 10:15 AM
Googling 64676746 didn't come up with anything, but a number like that is typical of Girling (which would explain the "G").
Old 11-29-2010, 12:30 PM
FWB's Avatar
FWB FWB is offline
with the straight port on top it looks like a truck application. VW bus?
Renault van?
Fred B
Old 11-29-2010, 12:51 PM
mickmate's Avatar
I'm thinking it might have to get a little replumbing and a Wilwood update.
mickmate
Old 12-19-2010, 07:04 PM
mickmate's Avatar
It was from a Rover car. I got a VW Super Beetle per the CCX manual. I had to slot the mounting holes and replumb the lines (metric to std) and I'm still dinking with getting it to work. I'll keep you posted but I don't recommend the VW master.
mickmate
Old 10-11-2013, 07:28 AM
Default brake master cylinder
i've been told that its a girling brake master cylinder used mainly in uk on rover 2000 2200 p6 and some austen healey vans
Old 10-13-2013, 10:28 AM
Danr55's Avatar
Old records from the build book say it's same as: Triumph Spitfire, 1968-1975, Mk 3 and Mk 4; BECK 0723924 Beck Kit 0710988.
Dan in Arizona
CCX3209
Old 10-25-2013, 07:35 AM
Cobra Make, Engine: Contemporary
This is a Girling Cylinder. Contact PowerTrack Ltd in the UK. They have a website. If you email them the pictures, numbers, and cylinder size, they should be able to help you. They are extrememly helpful. Just got a Clutch Slave Cylinder for my Contemporary.
Old 10-25-2013, 08:44 AM
CHANMADD's Avatar
Why not take that apart and rebuild it.........its the simplest thing .......
