Old 01-31-2012, 10:26 AM
Default Engine position?
Does anyone have a picture of the engine in the frame, body off? a side view is what I am looking for . I have mine installed what I believe is correct, however now I'm second guessing it. affectively the oil pan lip is at the top of the frame rails, this elevation is what I was told to be correct, that said it's does fit perfect, side pipes to frame, pipes thru the body even the transmission mount is dead on. The engine is right on parallel to the frame, the rear end center and lower control arms etc are exactly parallel also.
But....the engine is higher of course, so the drive shaft angle all beit parallel to the rearend,is offset more extreme. What is the down angle perameters? I think mine if I remember was close to 12-14 degrees, thats to much I thought for a short drive shaft.
Daniel
Old 01-31-2012, 12:21 PM
maybe this will help
Old 02-05-2012, 09:36 PM
Thank you, it does confirm my take on drive shaft angles.
I would still love to see a picture of the engine installed with body off.
Anyone???????????
just maybe apicture of the under side on a lift or jack stands???
Thanks , Daniel
