Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Old 07-18-2013, 08:45 AM
Cobra Make, Engine: Contemporary Classic, 427
Default Rebuilding jag steering rack
I have a jag series 1 steering rack on my Contemporary Classic. One of the balls broke off the tie rod, so I need to rebuild the rack. Does anyone know of a good reference manual that details how to rebuild the rack?
Old 07-18-2013, 09:01 AM
FWB's Avatar
FWB FWB is offline
is that all that is wrong? why not just replace the inner rod?
Fred B
Old 07-18-2013, 09:16 AM
The rack is off the car, so I thought I would rebuild it before reinstalling.
Old 07-18-2013, 09:58 AM
Try these guys, good guys to deal with. Classic Jaguar | The finest Jaguar restoration and performance parts in the world
Old 07-18-2013, 10:02 AM
Cobra Make, Engine: Power Performance Body, Contemporary chassis, 427 CO, Big I/O toploader, AMP Billet rear, Trigo 6 pin
Default look carefully
On the CC the balls are cut from the standard rack and moved out using a sleeve. The originals won't be a drop in.
Old 07-18-2013, 12:21 PM
Thanks, I have the measurements to lenghten the rods, found the correct length in the Manual.
Old 07-18-2013, 12:41 PM
mickmate's Avatar
Manual Rack Rebuild
Fred has a good point, it's mainly the sleeve bearings on the end. Secure it and give them a wriggle to see if they're loose. It can be a pain to replace them. The small pinion bearing wasn't the right size from the Jag dealer and I sourced those elsewhere.
mickmate
http://www.actoncustom.com/
Old 07-19-2013, 09:03 AM
Thanks for the rebuilding manual rack info, just what I was looking for. I am replacing the tie rods with the threaded rods I ordered from you.
Old 07-19-2013, 01:34 PM
Thor maine's Avatar
Manual Rack Rebuild
Mickmate do you make a full length tie rod. The cut ,sleeve and weld thing always gave me the willy's?
Old 07-19-2013, 01:57 PM
mickmate's Avatar
I do this which funnily enough looks a lot like the original tie rod extender.
Contemporary Tie Rod Uprated Contemporary Tie Rod Uprated [Contemporary Classic CCX 427] - $158.70 : Acton Custom Enterprises, Custom Metal for Cobras
mickmate
Old 07-23-2013, 05:30 PM
Danr55's Avatar
Here are some things to watch out for. where the spherical diameter meets the radius releif, beware of chips or other imperfections that could cause fatigue failures. I had one fail on my a couple of years ago. Nick (Mickmate) made some upgraded tie rods that are great.
These photos are of the one that hadn't failed yet. An analysis on the one that did fail indicated severe fatigue caused by repeated impacts. Teh left front wheel had a hell of a shake in it until I tightened up the steering. Notice the small chip just under the radius in the transition area. It would have failed within a few hundred miles.
Dan in Arizona
CCX3209
Old 07-24-2013, 04:54 AM
Thanks for the feedback, I think I will have my failed parts analyzed (and the other side that did not fail). I purchased 2 new tie rods from Nick (Mickmate) they looked great.
Old 07-26-2013, 05:45 PM
Danr55's Avatar
Look close in the radius on the part that hasn't failed yet.
Dan in Arizona
CCX3209
