| 29 |
5Likes
3
Post By CSX3183
2
Post By LMH
04-23-2019, 10:26 AM
Stellings and Hellings Foam Air Filter
Anyone can help getting a replacement foam air filter for the S&H assembly, I checked K&N and the filter that would fit KNN E-9181 is no longer being made.
04-23-2019, 11:17 AM
Cobra Make, Engine: FFR MkIV 427
Did you Google it? Summit appears to have it and it tells what vehicles it fits, so you could crossover to a paper filter.
Good luck
I made mine for the small dual quad Carters. Used air filter foam UNI.
Alba gu brąth
04-23-2019, 12:06 PM
You are correct the E-9181 is no longer available. But it may look odd being only 8" OD anyways.
From the forums. Most folks are using K&N E-1025 (8.25 X 2.5") or E-2570 (8.188 X 1.88") or E-2600 (8.188 X 2.18")
04-23-2019, 04:15 PM
OH
Stay away from K&N, they let in tons more dirt into your engine, well known fact, besides they look worse than turd sh-t
04-23-2019, 05:49 PM
The k&n type filter better than foam. But nothing beats paper (price or filtration).
04-24-2019, 09:27 AM
Cobra Make, Engine: owned Kirkham for 11 years
I bought a pair of foam filters from Tony Branda in Altoona Pa a few years ago.
Maurice
04-24-2019, 10:27 AM
These little tiny KNN E-9181filters are made for cars with 1.1 liter engines
I am pretty sure your car will greatly benefit from a larger air cleaner. Just a thought.
04-24-2019, 01:14 PM
Can't argue with the looks statement. I do recall seeing data on airflow and filtering efficiency comparing foam to paper to K&N (and maybe others?) showing K&N with better filtering and flow than foam, and better flow than paper (can't remember if the K&N also filtered better than the paper). Regardless it was enough to convince me to replace pleated paper filters on my modern cars. Never felt a difference, though, so who knows.
04-25-2019, 09:04 AM
Cobra Make, Engine: Superformance SPO2820 408W; former ERA CCX 3-3408 owner
..dirty, inefficient things
and the K+N' s cost a s#$% load more! I can't believe how much they get for those dirty, inefficient things. I'm glad I went with dry paper from the beginning on my Super.
04-25-2019, 06:49 PM
AL
I saw a test on eight air filter years ago. Of the eight test they did on the eight different brands of filters, K&N came in 7th or 8th in every category
But they have the best ad agency
04-25-2019, 08:02 PM
Just my opinion but beyond what filters best, what flows best, so on, nothing beats the looks of original style foam!
Alba gu brąth
04-26-2019, 12:23 PM
Just lightly oil the green foam.
If your car needs KN seems like crazy way to make an extra hp.
Doesn’t take much to get these little cars going
04-27-2019, 01:38 PM
oh
Cobra Make, Engine: Contemporary Classic
Foam media
Is the green foam available, where?
04-27-2019, 06:59 PM
Cobra Make, Engine: CSX4000 427 center oiler
If you have enough clearance under the hood, and want a taller element, try K&N NO-0100. It is one inch taller, 2 7/8" tall, while the one that came on my car is 1 7/8". 8" +/- diameter.
04-28-2019, 03:12 PM
UK
