Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree5Likes
  • 3 Post By CSX3183
  • 2 Post By LMH
Old 04-23-2019, 11:26 AM
GjC GjC is offline
Default Stellings and Hellings Foam Air Filter
Anyone can help getting a replacement foam air filter for the S&H assembly, I checked K&N and the filter that would fit KNN E-9181 is no longer being made.
Old 04-23-2019, 12:17 PM
MKS427's Avatar
Cobra Make, Engine: FFR MkIV 427
Did you Google it? Summit appears to have it and it tells what vehicles it fits, so you could crossover to a paper filter.
Good luck
LMH's Avatar
LMH LMH is offline
I made mine for the small dual quad Carters. Used air filter foam UNI.
Alba gu brąth
Old 04-23-2019, 01:06 PM
You are correct the E-9181 is no longer available. But it may look odd being only 8" OD anyways.
From the forums. Most folks are using K&N E-1025 (8.25 X 2.5") or E-2570 (8.188 X 1.88") or E-2600 (8.188 X 2.18")
Old 04-23-2019, 05:15 PM
Stay away from K&N, they let in tons more dirt into your engine, well known fact, besides they look worse than turd sh-t
Dwight, Ron61 and Hoodabest like this.
Old 04-23-2019, 06:49 PM
saki302's Avatar
Cobra Make, Engine: Superformance Mk3, Roush 427
The k&n type filter better than foam. But nothing beats paper (price or filtration).
Old 04-24-2019, 10:27 AM
Cobra Make, Engine: owned Kirkham for 11 years
I bought a pair of foam filters from Tony Branda in Altoona Pa a few years ago.
Maurice
Old 04-24-2019, 11:27 AM
These little tiny KNN E-9181filters are made for cars with 1.1 liter engines
I am pretty sure your car will greatly benefit from a larger air cleaner. Just a thought.
Old 04-24-2019, 02:14 PM
ACHiPo's Avatar
Cobra Make, Engine: ERA 824 with 470 FE BBM street 427
Can't argue with the looks statement. I do recall seeing data on airflow and filtering efficiency comparing foam to paper to K&N (and maybe others?) showing K&N with better filtering and flow than foam, and better flow than paper (can't remember if the K&N also filtered better than the paper). Regardless it was enough to convince me to replace pleated paper filters on my modern cars. Never felt a difference, though, so who knows.
Old 04-25-2019, 10:04 AM
timsullivan's Avatar
Cobra Make, Engine: Superformance SPO2820 408W; former ERA CCX 3-3408 owner
Default ..dirty, inefficient things
and the K+N' s cost a s#$% load more! I can't believe how much they get for those dirty, inefficient things. I'm glad I went with dry paper from the beginning on my Super.
Old 04-25-2019, 07:49 PM
Dwight's Avatar
Smile
I saw a test on eight air filter years ago. Of the eight test they did on the eight different brands of filters, K&N came in 7th or 8th in every category
But they have the best ad agency
Old 04-25-2019, 09:02 PM
LMH's Avatar
LMH LMH is offline
Just my opinion but beyond what filters best, what flows best, so on, nothing beats the looks of original style foam!
1985 CCX and ACHiPo like this.
Alba gu brąth
Old 04-26-2019, 01:23 PM
1985 CCX's Avatar
Just lightly oil the green foam.
If your car needs KN seems like crazy way to make an extra hp.
Doesn’t take much to get these little cars going
Old 04-27-2019, 02:38 PM
Cobra Make, Engine: Contemporary Classic
Default Foam media
Is the green foam available, where?
Thanks
Old 04-27-2019, 07:59 PM
sd427's Avatar
Cobra Make, Engine: CSX4000 427 center oiler
If you have enough clearance under the hood, and want a taller element, try K&N NO-0100. It is one inch taller, 2 7/8" tall, while the one that came on my car is 1 7/8". 8" +/- diameter.
Old 04-28-2019, 04:12 PM
Interesting, that K&N link takes me to this....
https://loretogallo.com/uk/bandage-r...=5ac5ea7f435ab
Crendon 427, in the making
http://crendonreplicas.com/
