Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Like Tree1Likes
  • 1 Post By xb-60
Old 08-19-2019, 10:10 AM
GjC GjC is offline
Default Fire Extinguisher
Just purchased a fire extinguisher for the CCX any suggestions on mounting? I was going to mount it in between the seats on the trunk bulkhead.
Old 08-19-2019, 07:23 PM
Danr55's Avatar
That's a good place for it.
Dan in Arizona
CCX3209
Old 08-19-2019, 11:09 PM
xb-60's Avatar
Before you mount it on the trunk bulkhead, how thick is the bulkhead sheet? If it is only 16g (1.6mm / 1/16") sheet alum. alloy, you would need to use a correct thickness "washer plate" on the trunk side to prevent the heads of the mounting screws pulling through the thin bulkhead. In a mild 10g deceleration, all of a sudden your 1kg / 2.2lb extinguisher becomes in effect 10 times that weight and the screw head would pull through a thin bulkhead.
Good idea to carry the fire extinguisher, but it needs to be mounted so that it's safe in all circumstances.
Glen
1795 likes this.
Old 08-20-2019, 07:19 AM
GjC GjC is offline
Thanks for the heads up. I'm using 4 plates of 1/6 metal to sandwich between the bulkhead so the mounting hardware doesn't pull through
Old 08-21-2019, 01:29 AM
lomdel's Avatar
Cobra Make, Engine: Backdraft RT3
Fire extinguisher mount
