Like Tree4Likes
  • 1 Post By Mongoose930
  • 1 Post By Danr55
  • 2 Post By mvanhorn8893
Old 03-22-2021, 02:06 PM
Default rear license plate bracket
Contemporary owners, what bracket or method did you use to mount your rear license plate?
Jon
Old 03-23-2021, 03:33 PM
On my contemporary the space is to small for a standard plate, I mounted it just under the trunk lip with a light
Old 03-24-2021, 07:39 AM
1985 CCX's Avatar
Trim a notch from plate to make it fit. Drill holes in boot lid and attach as originals.
Think in my old pics in gallery you can see the trim, its only a little.
Car, long gone.......
Old 03-24-2021, 02:32 PM
Good idea
Old 03-24-2021, 04:08 PM
Mongoose930's Avatar
Cobra Make, Engine: Hi-Tech
Trimmed a little off the top and bottom of the plate on my old Contemporary.
1985 CCX likes this.
Old 03-26-2021, 01:59 PM
Danr55's Avatar
Mine is attached to the top bar of the trim ring with zip ties.
MD427 likes this.
Dan in Arizona
CCX3209
Old 11-09-2021, 01:43 PM
Cobra Make, Engine: Contemporary 427SO, Top Loader
On my car, I made two vertical stainless plates 3/16" Thick x 3/4" wide to bolt to the bumper and tapped each one 4 places: two for #10-32 stainless oval head screws coming through the bumper tubes (from front to back) and two 1/4"-20 for license plate bolts.
On a friend's car we did the same but he didn't want to drill his bumper so we used rubber insulated Adel clips around the bumper
Old 11-09-2021, 08:08 PM
Cobra Make, Engine: Contemporary Classic Cobra CCX-3-3967
I couldn't use the bracket I bought from Finish line due to the recess on the Contemporary deck lid so I made a bracket to mount the plate to the trunk handle and it clears the light and handle nicely without trimming the license plate.
http://www.clubcobra.com/forums/pict...ictureid=19848
1985 CCX and Gaz64 like this.
Old 11-09-2021, 08:49 PM
"Mine is attached to the top bar of the trim ring with zip ties."
M
i
c
K
E
Y
MOUSE
Old 11-09-2021, 08:59 PM
Send a message via AIM to krausewich
Mine has two holes drilled under the trunk lip, so the plate hangs below the trunk. I placed grommets in the holes to clean up the look. Others have made an ally bracket that mounts behind the QJ and hangs under the taillight. Could it be mounted to the rollbar behind a headrest/harness setup?
Are there two forms of trunk lid? Euro / American?
-J. James
M. Krause
1.508.944.3368
Old 11-18-2021, 08:02 PM
Cobra Make, Engine: 1981 CONTEMPORY COBRA, 351C
I made some 5/8" aluminum plate, split brackets and mounted to the 2 bumper bars, came out really neat, would post pictures if I knew how
Old 11-18-2021, 08:20 PM
[IMG]20210212_164100.jpg[/IMG]
