Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Old 06-21-2022, 11:31 AM
Default Front shock
Looking for info-anyone have the measurements for their front shocks?
I need full length, full compression and ride height on the CCX's. my measurements are 15" full extension, 10 1/4" full compression with a ride height of 12". all measurements are center to center. Is that about the same with other CCX's. After I put all new rubber in the front end and took it for the wheel alignment the tech told me that the QA1's would work but I would have only have an 1 1/2" travel. I'm curious if others have similar specs? Don't want to install the new equipment and and bottom them out.
Old 06-21-2022, 11:49 AM
jknich's Avatar
Are these the QA1's you are looking at? Looks like a couple inches travel before bottoming. A lot of guys use 400 to 500lb springs on the front. You won't bottom out.
https://www.speedwaymotors.com/QA1-A...es,478661.html
Jim Nichols
