Old 10-20-2008, 04:29 PM
1985 CCX's Avatar
Here is what mine looks like now! Boy am I a show off.....
Positioned like this leaks just drip to the ground.
Old 10-20-2008, 04:52 PM
Cobra Make, Engine: Contemporary Classic CCX 3970: 1965 427 Cobra S/C, Shelby aluminum 427 CSX 290 (468 cu in) engine
Jeff: Your pedals look cool, I have some like that, but they're still in the box. o: But my immediate need is to identify my clutch master cylinder. I just talked to XKs Unlimited, but they don't think it is off an XKE. I was hoping to identify what mine is, order a new one, dump the old and bolt in the new. Might you have a photo of your master cylinder? Worst case, I'll take off my clutch master cylinder, take vital measurements, locate a similar component and order a new one. I just got the beast back on the road after a lengthy rebuild, and hate the idea of having to park it again: eek Rich
Old 10-20-2008, 08:02 PM
Cobra Make, Engine: Contemporary 427
Default I think I have the photo you need
try this, CCX 33660, 1991 vintage. had to scan photo.
Old 10-20-2008, 11:30 PM
Looks good, but do you know what kind of clutch master cylinder you have? Rich
Old 10-25-2008, 01:50 PM
badrich, my deluxe home builder kit was delivered with an under floor pedal setup in 1993 with c n c master cylinders. the clutch bore is 7/8 in. part # is 711-7/8 for steel with s/s sleeve.If you need polished I believe the # is 712-7/8 Jack Mack, ccx33806 oh, yeah , the chassis shop 1-800 -530-9494 has them and can get them to you in a few days.
Old 10-28-2008, 02:16 AM
Thanks, Jack, I decided to go with a 3/4" Girling from Pegasus, same as my brake master cylinders. I figured it would be large enough to work without too much leg pressure, especially compared to those mechanical clutches we used in the sixties. Rich
Old 11-04-2011, 02:17 PM
mickmate's Avatar
The trick to these is the heim jointed rod through both masters with the pedal pushing in the middle like this PhotoPost Classifieds - CNC dual master cylinder with adjustable bias - Powered by PhotoPost Classifieds
mickmate
http://www.actoncustom.com/
Old 11-04-2011, 03:48 PM
sharpe 1's Avatar
Cobra Make, Engine: Midstates,SBF 357
You might take a look at the Kirkham web site. They have some pic of their floor mount pedels.
Old 11-05-2011, 05:31 AM
mickmate's Avatar
Their balance bar isn't mechanically adjustable. They get front rear balance hydraulically like the originals. I found a pic Drew put up of his which is a good one.
Master brake cylinders
mickmate
