Old 03-06-2009, 02:21 PM
cobrarkc's Avatar
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
Default Ignition Resistor
Does anyone know what you need the ignition resistor for in the Contemporary. I am putting in a MassFlo EFI system which uses the Ford EECIV ecu coil TFI distributor and I am converting to an alternator with a voltage regulator on it, also am using an MSD 6AL box. Can I just remove this and the wires to it?
Cobrarich
Old 03-06-2009, 03:02 PM
Default MSD box
I think if your read the instructions on the MSD box you will find that it does not use a resistor. The resistor cut down the current available to the coil and reduced the heat build up in it.
Old 03-06-2009, 05:36 PM
Danr55's Avatar
Pull it out and throw it away. It's useless with an electronic ignition.
Dan in Arizona
CCX3209
Old 03-06-2009, 08:17 PM
cobrarkc's Avatar
Thanks Guys will do it.
Cobrarich
