February 2026
Old 03-24-2009, 06:45 AM
Danr55's Avatar
Default Lower Radiator Hose
What hose was used for the lower radiator hose that is between the frame and the radiator forward of the pipe section?
Dan in Arizona
CCX3209
Old 03-24-2009, 07:21 AM
Cobra Make, Engine: Contemporary CCX33344 with original bore 427 SO.
Default Hoses
From the CCX Manual
See attachment. I have these waiting to install.
Old 03-25-2009, 07:52 AM
Danr55's Avatar
Thank you.
Dan in Arizona
CCX3209
Old 03-25-2009, 08:30 AM
Dan, the Dayco 70794 is a napa 7577 from th water pump and the dayco 70781 is a napa 7679 to the lower radiator.on the steel tube i welded a threaded bung and installed a MR. Franks automatic fan relay hope this helps. Bob
Old 03-25-2009, 07:25 PM
Danr55's Avatar
THanks Bob. That will come in handy..
Dan in Arizona
CCX3209
Old 03-25-2009, 07:40 PM
Mdman352's Avatar
Cobra Make, Engine: Contemporary-427 stroker
Default radiator hose
I found that when reving the motor the hose on my car was collapsing so I bought a hose with a wire coil in it and removed the coil and installed it on my hose. works like a champ and no more issues.
