| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
07-15-2009, 06:27 PM
amp gauge
I am in the process of removing a radio and when I removed the dash I saw that the amp gauge terminals were melting. The problem being that the metal terminals were about to ground to the dash and possibly melt the car. Have a look before its too late.
07-15-2009, 08:33 PM
AZ
DId away with the amp gauge a while ago and replaced it with a volt meter.
Dan in Arizona
CCX3209
07-15-2009, 08:39 PM
CA
part 1. - There is an Autometer volt gauge that looks the part and wont have welding rods in your dash.
part 2. --As for the melting problem, it sounds like there is too much amperage running in that set of wires - are there things running through the car harness /fuesblock that could be offloaded to relays>?
Sugenstions : Fans, Headlights , ignition boxes , etc.
--Steve
07-16-2009, 06:53 AM
the gauge housing is plastic and 23 years old, its only a matter of time before it melts. I may use a volt gauge instead of the amp.
thanks
07-16-2009, 07:02 AM
CA
I had a voltmeter in my car and liked it a lot better than an amp gage.
07-16-2009, 11:56 AM
NY
Cobra Make, Engine: Contemporary Classic Motor Car; 427 S/O
Racco: I had a near meldown with the amp gauge (smiths). I replaced it with a Smiths Volt gauge. I spoke to Peter at Nisonger and he said it was a common occurence. I chased mine down for a bit of time. I kept selling hair burning. As it turned out it was the gauge from the inside out. The face was starting to melt when I found the problem.. Good catch... Go with the volt gauge eventhough it not period correct.....
07-17-2009, 05:33 AM
AZ
One serious downside to an amp meter is that if it goes, everything electrical in the car quits. Not a good thing if you are on the road 200 miles from home!
Dan in Arizona
CCX3209
07-17-2009, 08:15 AM
I agree with Ralph, I got the voltmeter for my CCX from Peter as well, it's a smart move.
07-17-2009, 01:48 PM
NY
Doug: Anything yet on the engine... Call me if you need anextra wrench hand when you start the assembly process....
07-17-2009, 02:24 PM
NH
The problem I see is most modern alternators put out way more than the ammeter can handle. They caused more than their share of fires on replicas and originals. Take the voltmeter advice I reckon.
