Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Old 07-15-2009, 06:27 PM
racco's Avatar
Default amp gauge
I am in the process of removing a radio and when I removed the dash I saw that the amp gauge terminals were melting. The problem being that the metal terminals were about to ground to the dash and possibly melt the car. Have a look before its too late.
Old 07-15-2009, 08:33 PM
Danr55's Avatar
DId away with the amp gauge a while ago and replaced it with a volt meter.
Dan in Arizona
CCX3209
Old 07-15-2009, 08:39 PM
PANAVIA's Avatar
part 1. - There is an Autometer volt gauge that looks the part and wont have welding rods in your dash.
part 2. --As for the melting problem, it sounds like there is too much amperage running in that set of wires - are there things running through the car harness /fuesblock that could be offloaded to relays>?
Sugenstions : Fans, Headlights , ignition boxes , etc.
--Steve
Old 07-16-2009, 06:53 AM
racco's Avatar
the gauge housing is plastic and 23 years old, its only a matter of time before it melts. I may use a volt gauge instead of the amp.
thanks
Old 07-16-2009, 07:02 AM
Ron61's Avatar
Post
I had a voltmeter in my car and liked it a lot better than an amp gage.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 07-16-2009, 11:56 AM
streetrod1927's Avatar
Cobra Make, Engine: Contemporary Classic Motor Car; 427 S/O
Racco: I had a near meldown with the amp gauge (smiths). I replaced it with a Smiths Volt gauge. I spoke to Peter at Nisonger and he said it was a common occurence. I chased mine down for a bit of time. I kept selling hair burning. As it turned out it was the gauge from the inside out. The face was starting to melt when I found the problem.. Good catch... Go with the volt gauge eventhough it not period correct.....
Old 07-17-2009, 05:33 AM
Danr55's Avatar
One serious downside to an amp meter is that if it goes, everything electrical in the car quits. Not a good thing if you are on the road 200 miles from home!
Dan in Arizona
CCX3209
Old 07-17-2009, 08:15 AM
767Jockey's Avatar
I agree with Ralph, I got the voltmeter for my CCX from Peter as well, it's a smart move.
Old 07-17-2009, 01:48 PM
Doug: Anything yet on the engine... Call me if you need anextra wrench hand when you start the assembly process....
Old 07-17-2009, 02:24 PM
mickmate's Avatar
The problem I see is most modern alternators put out way more than the ammeter can handle. They caused more than their share of fires on replicas and originals. Take the voltmeter advice I reckon.
mickmate
http://www.actoncustom.com/
