Old 09-05-2009, 09:09 PM
Smile Contemporary soft top
Will a Superformance cobra soft top fit a Contemporary car?
Regards,Mike
Old 09-06-2009, 02:28 AM
Danr55's Avatar
If the lift a dot pins are in the correct position, it should. They all use the same bows and the same attach points.
Dan in Arizona
CCX3209
Old 09-06-2009, 11:15 AM
1985 CCX's Avatar
Dan is correct!
Fitting would be required. If you do not have the pins for a top it will be easier, if you do would need assistance from a upholsterer...
Old 09-06-2009, 12:26 PM
Default Contemporary soft top
Jeff & Dan,
My car does not have the pins installed.
Thanks guys.
Mike.
Old 09-06-2009, 02:25 PM
1985 CCX's Avatar
Then a simple fitting with possible window angle correction and you should be good to go! Best of luck!
