Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > David Kee Toploader Transmissions Inc. Speak with David.
Old 04-03-2005, 11:06 AM
DrC DrC is offline
Cobra Make, Engine: ERA 711 390 FE w/ TKO 600
Default Tire clearance
I asked the members what brand of tires they liked. The general concensus was the Yokahamas. The one thing they all warned of was very close spacing on the rear with the 295/50/15. Have you had /have any concerns with the closeness to the fender on the rear with the big tread of the Yokahamas?
Old 04-03-2005, 11:35 AM
Eljaro's Avatar
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
In my case, with the Contemporary body and Jag front and rear suspension the rear tires is no concern, could probably even take a 325 like the BFG drag radial.
The front with a 245/60-15 is tight, and I would not go wider unless you raise the car and increase ground clearance. It all depends on the offset of the wheel.
It probably is very dependent on which Cobra you have. In any case, the 245/60-15 and 295/50-15 have the same height and look "right" on the car. I have the white letters in the inside, so unless you look close you will not see the Yokohama name on the tires.
Nothing sounds better than a Cobra in a Tunnel !
