06-30-2002, 07:53 PM
OH
Cobra Make, Engine: RCR SLC, Graziano 6-spd, LS3
Anyone in NW Fl have a 37 deg flare tool?
...that I could borrow?
I'd really like to run hardlines for fuel from the fuel pump to the engine compartment, then use AN tubing/fittings to the engine. But, I can't see paying $80 for a tool I'll use to make four flares.
Pete
06-30-2002, 08:17 PM
The longest build.....
KS
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
Hey,
Go to your local airport and find out where the guys hang out that restore antique airplanes.
Or ask one of the mechanics at the Beechcraft or Cessna dealer.
Most of those guys will gladly help you out.
Bill Cook
06-30-2002, 08:31 PM
KS
Plan B
Cut your line to the finished length and send the lines and fittings to me.
I spent the $95.00 and bought the Parker flaring tool for doing AN fittings. All my lines (fuel and brake are AN) are 37s.
I will flare them and return.
Just let me know !!!
Cheers again,
Bill Cook
07-01-2002, 04:28 PM
OH
Wicked Fast,
I appriciate the offer, but the lines are about 8' long. I can't even picture the mess they would be after UPS was done with 'em  . If I can't find anyone nearby I think I'll just run hose to the tank.
Pete
07-09-2002, 12:20 PM
WI
Cobra Make, Engine: Backdraft Racing #223
PSB,
You should be able to find a compression fitting that goes from hard line to A/N.
I purchased my set for the pressure and return lines from Amazon Hose here in Tampa.
Check your local shops and see if they have similar.
Ed
FFR1997K
I was told it doesn't get cold up here.
WTF... I'm freezing!
12-11-2003, 10:03 AM
GA
Cobra Make, Engine: Factory5, 5.0L
Flare Tool
PSB,
AutoZone has a Loan-a-Tool program that is great. You "buy" the tool, use it, then bring it back for a full refund. Double Flare Tools are in the program.
This is about the only useful thing AutoZone offers other than air fresheners and candy bars.
King Kobra
02-03-2004, 06:26 PM
fl
Cobra Make, Engine: backdraft racing 302 ford
hi
do you know any machinest I'am a tool & die maker by trade and have built 3 airplanes and now i"am into cobras cheaper to run.
take a 45 flare tool and turn it on a lathe to 37 useing the compound it only takes a min or so 45 are cheap and you can buy them anywhere i have made one for my home builts and they work geat
ED
Ed
02-03-2004, 09:47 PM
GA
Or you can spend $59 and buy one from: Speedway.com
02-06-2004, 06:35 AM
OH
Ummm....Thanks for the input guys, but I posted this question over two years ago.
Pete
02-06-2004, 07:12 AM
GA
I bet you're glad you finally got an answer so you can get on with finishing your car!!!!!
So what did you end up doing?
Pat
02-06-2004, 07:15 AM
OH
I put a 45 deg flare on the end of the tube and used a compression fitting and a NPT to AN adapter.
Pete
