  #61 (permalink)
Old 05-11-2004, 04:28 AM
Cobra Make, Engine: SPF 1345, 351W Stroker
Well i will jump in as a newbe and go for a number.
Jerry Miller: Superformance Mark III # 48
  #62 (permalink)
Old 05-11-2004, 05:27 AM
Johan's Avatar
Good job. It is OK to have duplicate numbers, just not in the same group...
  #63 (permalink)
Old 05-11-2004, 06:06 AM
Tommy's Avatar
Johan -
I'd like # 66 for my Cobra. If that's not possible, I'll have to tighten my shoulder straps, flip the car upside down and go with # 99.
Tommy
Previously owned EM Cobra
  #64 (permalink)
Old 05-11-2004, 07:19 AM
terry lee's Avatar
GEAR GRINDER CUM LAUDE
Cobra Make, Engine: SPF #1560 w/ Ford Racing [RDI/AFR/RPM] Alum. 427CI - 575HP & TKO
Johan,
Please put me on the list as;
Terry Lee #7 Shelby 427 Cobra (SPF replica)
TL
ps: I have a spare set of #11 for Daisey if she needs them.
BOYZ and TOYZ
With every day I grow alittle older -
BUT, I'LL NEVER GROW UP!
  #65 (permalink)
Old 05-11-2004, 01:10 PM
aumoore's Avatar
Cobra Make, Engine: Hunter 427, 5.0 (302)
Ok now I have to buy meatball's or is it gumball's? Well anyway has anybody got dibs on #09 or how about #34?
Click here for DSCC website
  #66 (permalink)
Old 05-11-2004, 02:46 PM
Johan's Avatar
last year you were 009. Check the first post in this thread, as I've updated it a little.
  #67 (permalink)
Old 05-11-2004, 03:17 PM
aumoore's Avatar
I would use 009 but I think the meatballs only come in two digits
  #68 (permalink)
Old 05-11-2004, 05:08 PM
#16, Cobra Daytona Coupe,
in the newby DE class
Chip n Atlanta
  #69 (permalink)
Old 05-11-2004, 07:17 PM
Cobra Make, Engine: Unique 289-FIA sold, sniff
I would like to reserve #86 for my 951 S and #861 for Adam's 944.
Also Johan I MAY have done a deal on a 996 Supercup this afternoon and if it pans out I'll bring it as #186. Keep your fingers crossed for me on tihs deal.
the number 86 is significant to me because the bartenders used to always remember my nickname "you're 86'd " they'd say and I would know that I was accepted.
There are several shops to do tire changes close-by.
Bring on those Cobras boys
  #70 (permalink)
Old 05-11-2004, 07:20 PM
Johan's Avatar
Rick, which cars go in which groups ?
  #71 (permalink)
Old 05-11-2004, 08:59 PM
Would like to use #52 ,have used it in Gainsville and it treats me good.
Paul Liparoto
  #72 (permalink)
Old 05-12-2004, 05:46 AM
Johan's Avatar
Glad you can come Paul. You've done some Gainsvilles ? Are you clear about the required gear ?
  #73 (permalink)
Old 05-12-2004, 08:43 AM
terry lee's Avatar
Johan,
Put Rick with the "Men-a-Paws" group.
TL
BOYZ and TOYZ
  #74 (permalink)
Old 05-12-2004, 06:43 PM
RD31's Avatar
Cobra Make, Engine: FFR 4071, SHP 408 Carb dry sump, G-Force T-5, 4 into 4 headers, 3-link 8.8 with 3.55 gears in the rear
Johan,
Hi, I haven't posted here yet but I am really looking forward to this event. I've been talking with Ed and I am about putting together an order for the rest of the gear that I need.
I would like to reserve 31 as my number if it's available. If not, then 71 is my second choice.
Robert
  #75 (permalink)
Old 05-12-2004, 07:01 PM
What are the catgories again? Can't find that post. cb
  #76 (permalink)
Old 05-12-2004, 08:01 PM
Johan's Avatar
Robert, have you been to a DE before ? Talk to Ed, he's been.
Chip, it is the first post of this thread.
Ed, do you have some sort of list or something ?
  #77 (permalink)
Old 05-13-2004, 03:58 AM
RD31's Avatar
Yes, I have been to a number of the events at Gainesville (I assume that is what a DE is).
I have a SA2000 helmet, but what I don't yet have are the arm restraints. I'm also ordering a neck support.
Here is Ed's list. He is in Jamaca right now basking in the sun. He won't be back until next Monday.
Short list of requirements:
1) Cotton or fire resistant long sleeve clothing, neck brace, arm restraints and fire extinguisher are mandatory. Fire suit is recommended. SA-95 rated helmet or newer. Snell or DOT rating insufficient.
2) This next one falls under the “Duh” category. Check for loose bolts, nuts, etc and tighten them, be sure to inspect tires, brakes and all fluids. Grease all bearings and fittings, etc. Again I will mention this event is 24 hours of track time… BRUTAL!
3) Oil drain plug must be safety wired or at a minimum taped in place. Double check all fittings!
4) No radiator coolant other than water and or water with wetter. No antifreeze!
5) Car number, meatball or tape.
6) Upgraded brake fluid and pads are also recommended to enhance your enjoyment.
Robert
  #78 (permalink)
Old 05-13-2004, 05:56 AM
Johan's Avatar
Cool, glad you can come Robert. You also need 2 (two) throttle return springs.
JW
  #79 (permalink)
Old 05-13-2004, 08:22 AM
terry lee's Avatar
Just a clarification question on requirements:
Is the neck brace MANDATORY?
I am assuming the reference is to the horse collar type (that big bulky sum of a batch).
I got everything else covered.
Well not quite, need more tires!!!
"My cheerleader" about soiled her panties when I told her I needed another set or 3 of race tires. Word of advice to all my young married friends out there: ALWAYS, ASK FOR MORE THAN YOU WANT; That way you can negiotate down to what you originally wanted in the 1st place.
Let's keep this our little secret.
TL
BOYZ and TOYZ
  #80 (permalink)
Old 05-13-2004, 10:24 AM
Johan's Avatar
I would rather see you in a proper driving suit than a neck coller thing. Nobody wants to wear this stuff, but s**t happens....
