Go Back   Club Cobra > Archives > Double Venom Spring Fling
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 06-20-2004, 12:36 PM
ROSS WEAVER's Avatar
Default Racing Fuel
I am looking for gas stations that have racing fuel. Any of you Columbus locals know of any locations? 110 octane preferably. Are there any close to the hotels?
Ross
Old 06-20-2004, 01:20 PM
historicmustang's Avatar
Cobra Make, Engine: 1965 Mustang Road Racer
Ross, are you sure you can not get away with using 100 octane at Union 76? I have run this for years with no problem. In the 110 to 120 range I was burning off the tips on the plugs.
Henry
Old 06-20-2004, 07:38 PM
I ran 11.9 at 121 mph with 92 octane today. Not bad for cheap gas!
Old 06-21-2004, 04:20 AM
Historicmustang,
I can probably use 100 octane. That would be better than the usual 93 octane.
I am still looking for locations in the Columbus area (close to the hotels) that carry racing fuel.
Ross
Old 06-21-2004, 06:15 AM
dalola's Avatar
Cobra Make, Engine: Project "X" underway....twin turbo V6, AWD...
Ross,
The Certified station in Marysville(30-40 minutes from the 'Fling hotels) has CAM2 for $3.85 gal. Been this price for years, even as regular gas prices are all over the place. Obviously, they do a good business, so it's always fresh.
If you want more info, directions, etc..., just let me know.
~Dave
Old 06-21-2004, 06:46 AM
Dave,
Thanks for the info, but I would like to find something closer to the hotels as my car only gets 6-7 mpg. The price you quoted is about right for racing fuel. At least it hasn't gone up like regular pump gas.
Ross
Old 06-21-2004, 07:32 AM
Cobra Make, Engine: FFR2229K, Vortech-blown 306 (446rwhp, 442 rwtq)
I'm curious...what are the specs on your engine? I'm a little surprised that a 560HP 460 *needs* race fuel. There's no real benefit to running it if your engine doesn't need it.
Wade Chamberlain
Old 06-21-2004, 07:33 AM
Clois Harlan's Avatar
Unless I am at the track I take my 15 gallon bbl to one of our local small airports and fill up with 102 octane leaded aircraft fuel. Cost is about $2.42 gallon. Same stuff you pay $3.75 for at the speed shops. You must take a container because it is illegal for you to introduce leaded fuel from the pump into a street vehicle.
Clois
"Let's roll"
"Be part of Something Good
Old 06-21-2004, 08:12 AM
Wade,
The compression of my engine is 11:1. It will run on pump gas, but not very well.
Ross
Old 06-21-2004, 08:22 AM
clayfoushee's Avatar
Cobra Make, Engine: Unique, 427SO, it runs
Clois,
I heard a compelling explanation a while back about why Avgas is a bad idea in an auto engine....something significantly different about the blend. But, since old age is beginning to set in, I can't remember the actual details.
Clay
Old 06-21-2004, 08:35 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
because avgas has to meet tests for different atmospheric conditions, actually burns slower than auto gas. All the tests I've ever seen, show hp loss using avgas.
Jack
XSSIVE .....
Old 06-21-2004, 09:19 AM
Jack,
Makes sense, because those GA piston engines are pretty low compression.
Clay
Old 06-21-2004, 11:30 AM
I need the lead in the avgas to prevent detonization so what I do is mix roughly 50/50 blend w/ either 93 or 95 octane that I can buy at the pump. I guess one could mix their own leaded ethyl gas at home with a little peroxide. I think that thread has passed through here once before.
Clois
"Let's roll"
Old 06-21-2004, 01:25 PM
Hotfingrs's Avatar
Lead doesn't prevent detonation, lead was used as a lubricate. The old valve seats weren't as hard as the ones for unleaded fuel. The octane number is your guide to preventing detonation or pre-ignition.
Jack
XSSIVE .....
Old 06-21-2004, 03:16 PM
Cobra Make, Engine: Superformance, 460/560hp
Send a message via AIM to jgrice
Ross - hope all is well with you....
You know we have the same motors....I had asked John Vermerish about fuel the last time I had my car to his shop....he said I was wasting money on anything above 94 octane as our motors did not require it. He went on to say it might even run better with 94 or 92/93 mixed with 100.
While I like the smell and color in the pipes of Turbo Blue and alike, I've been burining 93/94 octane for over a year and she runs fine.
Just my 2 cents.
Have fun.
Jeff - 186
Old 06-21-2004, 03:33 PM
Jeff,
I tried just running 93 octane and it runs very rough, backfires coughs, all kinds of s**t. I found that it runs best when I mix racing fuel and pump gas 50/50 or straight racing fuel.
Ross
