December 2025
Old 10-19-2009, 12:19 PM
CobERA's Avatar
Cobra Make, Engine: ERA #644 428 FE
Default 5 or 6 Point Belts on an ERA?
Has anyone installed 5 or 6 point seatbelts on their ERA? If so, where/how did you attach the submarine strap(s)? Any other details of the installation would be appreciated.
Thanks,
Rick
ERA 644
I'm getting old too fast and smart too slow!
Old 10-19-2009, 12:41 PM
tboneheller's Avatar
Cobra Make, Engine: E.R.A. #505
I installed 5 point harnesses on mine. I removed the seat cushion & wrapped the submarine belt around the front of the seat frame.
Old 10-19-2009, 01:57 PM
Five points are fine. Without attaching anything, layout the harness with you in the seat to check the lengths you'll need.
Drill a hole through the floor which is clear of the X-member and under the approximate middle of you seat. Get a grade 8 bolt as big as the hole in the belt mounting tab (usually about 1/2"), and a 4" square, 1/8" thick steel flat gusset plate. Drill same as floor. Use grade 8 nut and washer. Install the bolt with the head 'up'. Install with gusset under floor and space the tab off the floor with a washer. Through bolt the assembly.
Don't attach the belt to the seat frame.
Chas.
Old 10-19-2009, 02:11 PM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Used a 1/2 in. Grade 8 (5 is OK) bolt down through the floor with a fender type (large OD) washer to spread the load. Installed the seat-belt tab centered between the seat tracks and pointing forward to a rear-most position so the ERA floormat would fit. The floormats go in the trailer for track events.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 10-19-2009, 05:43 PM
Cobra Make, Engine: ERA 427 SO
Rick, I did what Charles and Tom did...installed a 5-point with a grade 8 bolt, a HD fender washer under the floor pan (but bolted the submarine belt anchor directly to the floor, no spacer) and a lock washer. I now wish I had installed 6-point belts, but these will do.
Ken
Old 10-20-2009, 09:21 AM
CobERA's Avatar
Thanks everyone for your responses.
I've decided to upgrade/replace my seven year old belts with a new 5-point system. Ordered the 4x4 mounting plates from Jegs and ordered the 5-point harness directly from Crow Enterprises. They make the belts for ERA, so they will be custom sized. I also orderd them without the Crow logos. Because I'm getting lazy, I orderd them with a camlock instead or the duck bill latch. Added a velcro sternum strap and velcro harness pads. John at Crow said they'll ship tomorrow.
Ken - Good to hear from you. If you've been keeping up with the Houston Group, you probably heard about this weekend's incident.
Rick
ERA 644
