Old 06-14-2010, 06:49 AM
Loadco's Avatar
Cobra Make, Engine: ERA 427 SC
Default Fan Thermostat Switch
Bob,
At what temperature should the switch close and start the fans?
ERA #509
2003 Z06
Old 06-14-2010, 07:40 AM
It turns the fans on at roughly 195F on the gauge. The actual water that passes the switch is in the return line of the radiator, so it will be cooler than at the head, so the switch is rated at only 78C (175F).
Old 06-14-2010, 10:13 AM
Loadco's Avatar
Thanks Bob,
I gusess I will be calling and ordering a switch. My fans are turning on when the gague shows 82C.
ERA #509
2003 Z06
Old 06-14-2010, 10:33 AM
Originally Posted by Loadco View Post
Thanks Bob,
You might want to use one of those little infrared temp guns to confirm that it's not your gauge reading wrong and the switch is working fine.
Old 06-14-2010, 10:38 AM
mrmustang's Avatar
Gold Star Contributor
Thanks Bob,
Do you know what temperature thermostat you have installed?
Bill S.
Old 06-14-2010, 11:41 AM
Loadco,
What is the normal operating temperature when the car is at speed?
Old 06-15-2010, 04:15 AM
Loadco's Avatar
Bob,
Water stays between 78C and 82C at speed depending on ambient temps. Oil temp runs about the same. Running 180F t-stat.
ERA #509
2003 Z06
Old 06-15-2010, 07:42 AM
I'd replace the switch. I can send you one, or you can get an 82C version from Autohauz (823 959 48182).
Old 06-15-2010, 07:52 AM
Loadco's Avatar
Thanks Bob,
I'll give you a call.
ERA #509
2003 Z06
Old 06-23-2010, 04:22 AM
Loadco's Avatar
Bob,
I think I am going to try the 82C version. Can you verify the phone number for Autohauz. You version has one too many numbers.
ERA #509
2003 Z06
